Author Topic: Part Number for Nardi Hub 280SL  (Read 3962 times)
« on: October 25, 2020, 11:29:48 »
I am searching the topic on the forum, but cannot find direction, please kindly help: there are two part numbers on Nardi website for hubs for Mercedes cars (tutti modeli 68-75)
4370.95.2802
Which one is best for 280SL? What is the difference between them?
Please kindly help.
sandcrab59
  • USA, MA, Lunenburg
Re: Part Number for Nardi Hub 280SL
« Reply #1 on: October 25, 2020, 14:15:54 »
I would like to know the answer also.
I have 2 Nardi wheels, one a complete set, and the second does not have the hub.
When I know the correct part Number I can order the missing hub.
Then I have two complete steering wheels.
Tom M
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
« Reply #2 on: October 25, 2020, 18:09:31 »
Nardi do not sell the hub for early 230/250 cars so try to order both and see if one comes up unavailable. If it does that will be the one you don't want!
« Last Edit: October 26, 2020, 16:35:46 by stickandrudderman »
« Reply #3 on: October 25, 2020, 18:15:51 »
I am after hub part number for 280SL that they sell. They have two part numbers, I have no idea which one is correct and what is the difference.
sandcrab59
« Reply #4 on: October 26, 2020, 00:55:41 »
I went to the Nardi website and it is not so helpful.
So I sent an email, they will respond tomorrow.
Wait and see.
Tom M
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1997 Corvette C5
« Reply #5 on: October 26, 2020, 07:25:42 »
Thank you. I also tried the website and I also have sent them an e-mail. My trouble is I will be probably re-directed to the local distributor who has no idea what he is talking about.
« Reply #7 on: October 26, 2020, 08:26:01 »
This might work.
https://www.northstarmotorsports.com/products/sfID1/Car/sfID2/Interior+Vehicle+Accessories/sfID3/Hub+Adapters/manufacturer/MOMO/productID/8569
That link is for Momo, not Nardi and in any case only lists one part for all models. Early cars need a different hub from later ones due to the different steering wheel.
« Reply #8 on: October 26, 2020, 09:45:38 »
Nardi have redirected me to the Austrian distributor - I asked the question there.
I understand (correctly?) - is Momo collapsible and Nardi not?
« Reply #9 on: October 26, 2020, 17:05:52 »
This is what I got recently from the UK distributor:
Only 4302.14.2802 is available and it has the following dimensions:
47 splines
Diameter of the central hole : approx. 15,20 mm.
Total height : 109 mm.
« Reply #10 on: October 26, 2020, 20:22:25 »
I have received information from the Nardi distributor in Austria,
https://classic-wheels9.webnode.com/unser-angebot/mercedes/#!
4370.95.2802 - more modern, collapsible
4302.14.2802 - older model that looks better in a Pagoda due to the shape; all aluminum
Both available.
Pictures attached.
sandcrab59
« Reply #11 on: October 28, 2020, 01:33:15 »
Pawel:
How do you order the center pieces.
Ring and Horn button.
Also on my complete set. how do you take it apart?
I do not see instructions.
Tom Mrowka
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1997 Corvette C5
« Reply #12 on: October 28, 2020, 08:27:22 »
Tom, I just ordered them from the distributor I mentioned.
I asked Nardi to direct my query to a distributor but not the one they had in Poland as the Polish distributor did not care about what I wanted. So they gave me the Austrian one.
I ordered Anni 60's wheel.
Two types of hubs are available for 280SL.
Horn buttons with Mercedes star come in ivory, blue, black or burgundy colors.
I have no idea how to pull apart the parts - I have not seen them yet.
sandcrab59
« Reply #13 on: October 28, 2020, 12:34:07 »
Pawel:
What is anni 60's wheel.
The 2 hubs in your post are not like the one I have.
Mine must be an old version.
Mine is just straight down, it does not have ribs or cut outs like in your pictures.
On the bottom where it contacts the steering wheel it has a small center ring with the name Mercedes.
There is a number 3202 in the aluminum part.
Tom M
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1997 Corvette C5
« Reply #14 on: October 28, 2020, 16:21:19 »
It may be an older hub, it may be a Momo hub - I have seen references to no. 3202 in many posts here on the forum.
Anni 60s is the model of the Nardi wheel. My wife said it is the only one that she likes and it was the end of discussion. Link to look at:
https://classic-wheels9.webnode.com/unser-angebot/mercedes/#nardi-380-mahagoni-mercedes-gross-schwarz-60-027-jpg
Amd the whole range here:
http://www.nardi-personal.com/personal/index.php?lang=en
sandcrab59
« Reply #15 on: October 28, 2020, 21:14:04 »
Pawel:
Your first classic 9 has pictures where one or two shows the ring that is on my steering wheel.
The center horn button varies. any one will do.
But where is the detail on parts and pricing.
Also instructions on how to take apart the ring, horn button and eventually the hub.
The site is nothing but pictures.
Tom M
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1997 Corvette C5
« Reply #16 on: October 28, 2020, 22:35:34 »
Pricing you get from distributors when you ask them.
Instructions - I guess you could ask Nardi directly. You have a contact form there.
On the Nardi page you have the hub catalogue in pdf.
Desertpagoda
  • USA, AZ, Tucson
« Reply #17 on: November 08, 2020, 18:31:15 »
Nice! that guilloche deco is pretty! How expensive are Nardi hubs these days?
kb
« Reply #18 on: November 08, 2020, 18:35:31 »
I was offered for Eur 60 as I was buying the wheel. I think normally around a Eur 100?
