Author Topic: What is this?  (Read 2892 times)
mauro12
  • Italy, Sicily, Messina
What is this?
« on: October 28, 2020, 10:48:15 »
Hi guys , I have just noticed this cable from the underside of my car. I cannot understand what is it. It seems very loosy and I scared it Could hit something on the road. Can you help me?
Thank you
Mauro Pisani
250sl 1967 5speed zf manual
Re: What is this?
« Reply #1 on: October 28, 2020, 11:37:07 »
Hi Mauro,
Looks likes the Parking brake cable.
^Peter
mauro12
Re: What is this?
« Reply #2 on: October 28, 2020, 11:42:29 »
Do you think it needs to be replaced or what? The parking brake is working fine. Maybe needs to be pulled?
Mauro Pisani
Re: What is this?
« Reply #3 on: October 28, 2020, 12:26:07 »
Usually the cables hang loosely under the car when the parking brake is  not used, but not so far down as on the picture.
I suggest to first check if they can to be adjusted.
^Peter
mauro12
Re: What is this?
« Reply #4 on: October 28, 2020, 12:57:53 »
Yes right now the parking brake is not pulled. When the car is in flat ground I prefer to put in gear rather than with brake. Should be easily fixed right ?
Mauro Pisani
Re: What is this?
« Reply #5 on: October 28, 2020, 13:16:18 »
Nope, not parking brake cable, but the Speedo cable.  Thick soft rubber insulation on half of it is the clue.
Use a small zip tie to hold it closer to the transmission.
mauro12
Re: What is this?
« Reply #6 on: October 28, 2020, 13:28:24 »
The Speedo cable ? I didn’t know that was doing such a route around the gearbox . I have to raise the car and should be easily fixed right?
Mauro Pisani
Re: What is this?
« Reply #7 on: October 28, 2020, 14:12:14 »
Yep, raise and tie the cable up, wire, zip tie at the point where the clutch is, allow the cable to keep a curve, not bent at point in rear where inserts to transmission.
yves
  • France, Poitou-Charentes
Re: What is this?
« Reply #8 on: October 28, 2020, 17:58:21 »
Here is the speedo cable
yves
Re: What is this?
« Reply #9 on: October 28, 2020, 18:00:51 »
here is the speedo cable at the box
mauro12
Re: What is this?
« Reply #10 on: October 28, 2020, 19:13:52 »
Thank you, I will bring the car to my mechanic because I don’t have the jack stands. In case this cable need to be replaced, is there a spare part?
Mauro Pisani
