with our official
Pagoda SL Group logo
from our official partner.
General Discussion
What is this?
Topic: What is this? (Read 2896 times)
mauro12
Full Member
Gold
Italy, Sicily, Messina
What is this?
October 28, 2020, 10:48:15 »
Hi guys , I have just noticed this cable from the underside of my car. I cannot understand what is it. It seems very loosy and I scared it Could hit something on the road. Can you help me?
Thank you
Mauro Pisani
250sl 1967 5speed zf manual
Full Member
Silver
Netherlands, North Brabant, Helmond
Re: What is this?
October 28, 2020, 11:37:07 »
Hi Mauro,
Looks likes the Parking brake cable.
^Peter
mauro12
Full Member
Gold
Re: What is this?
Reply #2 on:
October 28, 2020, 11:42:29 »
Do you think it needs to be replaced or what? The parking brake is working fine. Maybe needs to be pulled?
Mauro Pisani
Full Member
Silver
Re: What is this?
Reply #3 on:
October 28, 2020, 12:26:07 »
Usually the cables hang loosely under the car when the parking brake is not used, but not so far down as on the picture.
I suggest to first check if they can to be adjusted.
^Peter
mauro12
Full Member
Gold
Re: What is this?
Reply #4 on:
October 28, 2020, 12:57:53 »
Yes right now the parking brake is not pulled. When the car is in flat ground I prefer to put in gear rather than with brake. Should be easily fixed right ?
Mauro Pisani
Full Member
Platinum
USA, MD, Wheaton
Re: What is this?
Reply #5 on:
October 28, 2020, 13:16:18 »
Nope, not parking brake cable, but the Speedo cable. Thick soft rubber insulation on half of it is the clue.
Use a small zip tie to hold it closer to the transmission.
mauro12
Full Member
Gold
Re: What is this?
Reply #6 on:
October 28, 2020, 13:28:24 »
The Speedo cable ? I didn’t know that was doing such a route around the gearbox . I have to raise the car and should be easily fixed right?
Mauro Pisani
Full Member
Platinum
USA, MD, Wheaton
Re: What is this?
Reply #7 on:
October 28, 2020, 14:12:14 »
Yep, raise and tie the cable up, wire, zip tie at the point where the clutch is, allow the cable to keep a curve, not bent at point in rear where inserts to transmission.
yves
Full Member
Silver
France, Poitou-Charentes
Happy owner of a 69/ 280 sl , 63 Etype ,55 XK 140
Re: What is this?
Reply #8 on:
October 28, 2020, 17:58:21 »
Here is the speedo cable
Happy owner of a 69 blue 280SL , 63 FHC osb E-type , 55 FHC XK 140 to be restored...
yves
Full Member
Silver
Re: What is this?
Reply #9 on:
October 28, 2020, 18:00:51 »
here is the speedo cable at the box
mauro12
Full Member
Gold
Re: What is this?
Reply #10 on:
October 28, 2020, 19:13:52 »
Thank you, I will bring the car to my mechanic because I don’t have the jack stands. In case this cable need to be replaced, is there a spare part?
Mauro Pisani
General Discussion
What is this?
