Author Topic: Engine sputtering at low revs - occassionally  (Read 1814 times)
franjo_66
  • Australia, NSW, Point Piper
« on: October 29, 2020, 22:56:58 »
Hi All
Up until a few days ago my 230SL has been driving perfectly. Easy starting hot or cold, smooth acceleration, perfect engine temp in all conditions etc.
Lately, it will sputter and choke from take off or at low revs when accelerating. Does not happen when engine is cold or during first 5-10min of driving.
When it does happen, the engine will occassionally stop. But then these symptoms don't occur everytime I take off from a red light or similar. Acceleration past 2,000rpm is always smooth with no sputtering or choking.
Car has new plugs, fuel filter, etc done about 1,000km ago.
Fuel pump was redone by Pacific Injection 9,000kms ago with injectors. At the same time I installed a new fuel tank, strainer, 123 distributor, ignition leads (copper core) and new red Bosch coil.
Sounds to me like an intermittent fuel issue. Should I be checking fuel delivery/flow as a first port of call? Appreciate your input as to where the first set of checks should be focused as the intermittent nature of this issue has me stumped.
Franjo
Franjo
1965 230SL Black/Auto/RHD
2005 Porsche Cayenne Turbo
1983 BMW 735i
1986 560 SEC
1991 500SL
1982 Holden Statesman DeVille
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
Re: Engine sputtering at low revs - occassionally
« Reply #1 on: October 29, 2020, 23:00:47 »
Shot in the dark... but check your distributor to make sure any of the screws in there with the points or auto advance / retard didn't come lose or fall out.    If only when warm could it be a internal break in one of the wires heading into or within the distributor?
Ian
69 280SL
65 F-100
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
08 NPS50
12 Pro 4X
franjo_66
« Reply #2 on: October 29, 2020, 23:37:40 »
Hi Ian
The distributor was the first area I checked yesterday. All wires and connections are good and the distributor body is not loose.
I have not opened her up to have a look, but sounds like it is worth checking.
Franjo
Franjo
1983 BMW 735i
1986 560 SEC
1991 500SL
chumps
  • USA, CA, Santa Rosa Valley
« Reply #3 on: October 30, 2020, 01:19:21 »
The exact problem I had about a year ago. Turned out it was a loose wire on the coil. Tightened it, problem solved. Worth a look. Chumps
