Author Topic: What torque for the Box bolts ?  (Read 1766 times)
yves
  • France, Poitou-Charentes
« on: November 01, 2020, 06:30:47 »
I am reassembling the rear cover plate of the Box after replacing the radial shaft  seals  and wonder what is the torque for the bolts showed on the photo below  ?
They seem  have some thread lock when i have unscrewed them but need a confirmation.
I don't find these torque value on the BBB  which shows another kind of box
MikeSimon
  • USA, OH, North Royalton
Re: What torque for the Box bolts ?
« Reply #1 on: November 01, 2020, 14:49:04 »
yves: Haynes says Rear Cover Bolts large 45Nm, Rear Cover Bolts small 15Nm. I hope those are the ones. They are called 'bolts' and you show "nuts", but this is the only thing I could find for rear cover.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
yves
« Reply #2 on: November 01, 2020, 19:11:58 »
Thank's Mike  you are right , 1 is a bolt with two threads opposite  and nut at the middle  2 is the nut for the bracket for the rubber box fixation
