Author Topic: Latest dumb question - Steering  (Read 3832 times)
« on: April 07, 2005, 12:14:07 »
Mine has started creaking
One side (left) and when I am going slowly (maybe it's just then I hear it) and only when near centre (eg start of turn and end of turn)
It feels like something needs lubricant (can feel it in the steering wheel), and sounds like something needs lubricant
I am hoping it is something that needs lubrication ;)  as opposed to something needing some shiny new piece of latex that can only be replaced by dismantling half the car and is terminal if not replaced before something starts creaking :D
Any web-based diagnostics?
« Last Edit: April 07, 2005, 12:15:42 by Tosh »
Re: Latest dumb question - Steering
« Reply #1 on: April 07, 2005, 12:28:27 »
Hey Tosh. How are your subframe mounts? My car had a creak on slow turns... and I had 41 year old, rather perished mounts...New ones cured the problem for me!
« Reply #2 on: April 07, 2005, 14:03:57 »
No idea, I'll have a look in daylight
Interestingly, just went for a drive in the rain, and no noise on my return
rmmchl
  • USA, WV, Charleston
« Reply #3 on: April 07, 2005, 20:22:01 »
where are the sub-frame mounts? What are they made of? Easy to change?
michael romeo
1967  250sl
signal red
« Reply #4 on: April 07, 2005, 21:32:06 »
Here's a sedan article, but it pretty much applies to our roadsters.
http://www.mercedesshop.com/Wikka/W108Subframe
« Reply #5 on: April 08, 2005, 16:54:49 »
In addition to that informative link, there is some info here in the technical articles. Mostly why you should replace them if they are shot.
I can tell you that the subframe kit runs about 100 bucks (US). Labor is probably 3-4 hrs? if a good mechanic does it. This is a good time to change shocks too -- since they come out anyway...
I just had my subframe mounts, 3 engine mounts, rear diff. mount and front & rear shocks changed last summer -- it's so worth the cost.
« Reply #6 on: April 11, 2005, 08:17:46 »
The article posted below is a pretty decent guide to changing the sub-frame mounts, although there are some differences when doing a W 113.  Figure a day or so to do it yourself.  The mounts have metal inner and outer sections, with rubber between.  The rubber is what dies and allows the mounts to collapse.
Other things to change while you're at it are the front motor mounts and front brake flex lines, if they need it.
