Author Topic: Power wires from frigeking unit ?  (Read 2645 times)
Fab
  • France, Île-de-France, VITRY SUR SEINE
« on: November 05, 2020, 13:28:37 »
I have two power wires not connected from frigeking unit firewall side.
Can someone show me where these 2 power wires are connected ?
Thanks in advance.
1970 280SL Auto
1982 280CE Auto
1987 560SEC Auto
1992 500SL AMG 6L Auto
Re: Power wires from frigeking unit ?
« Reply #1 on: November 05, 2020, 20:11:19 »
Two wires leave the Frigiking Wiring Harness, one is the power supply (+) and the other is the control (on/off) of the compressor.
^Peter
Fab
Re: Fils électriques de l’unité de frigeking?
« Reply #2 on: November 05, 2020, 21:32:10 »
Thank you Peter.
But where are these 2 wires connected ? Do you have a picture ?
1970 280SL Auto
1982 280CE Auto
1987 560SEC Auto
Fab
« Reply #3 on: November 07, 2020, 08:10:25 »
Nobody can show me where are these 2 wires connected ?  :'(
Thanks in advance.
1970 280SL Auto
1982 280CE Auto
1987 560SEC Auto
« Reply #4 on: November 07, 2020, 10:24:40 »
I do not have pictures, but the cable to switch the compressor is going to the one cable on the compressor, maybe first going via a pressure sensor, to switch off in the case there is a gas leak.
The supply (+) is connected before fuse 2, with own fuse.
^Peter
Fab
« Reply #5 on: November 07, 2020, 11:38:30 »
Thank you Peter.
Where is the fuse 2 ? In the main fuse box ?  :(
1970 280SL Auto
1982 280CE Auto
1987 560SEC Auto
« Reply #6 on: November 07, 2020, 15:54:44 »
See pictures below.
• The supply (+) is, in my car is connected before fuse 2, with own fuse.
• It should not be necessarily fuse 2. It can be nearly any fuse as long as it has no current when car is switch off.
• You/one can also use the fuse box (if available on your car), right side engine bay which is used (one fuse) for the radio.
Where it is actually connected in your car depends on the aircon-installer.
^Peter
Fab
« Reply #7 on: November 07, 2020, 17:02:37 »
Ok Peter, i understood, i have a the fuse box right side engine bay.
But, for the compressor, i don't see a pressure sensor. The second wire is connected directly to the compressor ?
1970 280SL Auto
1982 280CE Auto
1987 560SEC Auto
« Reply #8 on: November 07, 2020, 19:08:40 »
That is possible, when they initially installed the air-conditioner system it was not common to add the pressure sensor.
I suggest to add this as it prevents to damage the compressor when there is no gas in the system.
^Peter
« Reply #9 on: November 07, 2020, 19:19:20 »
That means the second cable is directly connected to the compressor.
^Peter
Fab
« Reply #10 on: November 08, 2020, 11:03:43 »
thank you so much Peter.  ;)
1970 280SL Auto
1982 280CE Auto
1987 560SEC Auto
