Author Topic: Unwarping Door Panels  (Read 9036 times)
« on: April 07, 2005, 12:35:14 »
Can it be done? Any creative ideas on how?
Hate to buy new ones when my upholstery is still darn good -- its just that the panels have bowed bigtime.
And no, there is not a plastic sheet behind them and hasn't been for a long time. Shame shame. The inner door bottoms have not rusted, however, so that is good.
Re: Unwarping Door Panels
« Reply #1 on: April 07, 2005, 13:24:12 »
James,
Wood warps towards the side that's wet and it is sometimes possible to re-warp wood in the opposite direction by wetting the other side. If you have a steamer for removing wrinkles from clothes, it may be worth a try but I'd imagine your wood is very brittle.
« Last Edit: April 07, 2005, 13:25:37 by Douglas »
« Reply #2 on: April 07, 2005, 17:37:37 »
Thanks Douglas. I thought about taking a hot shower with my panels ... (for the steam, you smart-alecks out there)...
Now when you say wood -- I assumed the doors were more of a rigid cardboard. In my case the warping appears to be away from the wet side (as it is bulging into the interior). But it could be brittle nonetheless.
BHap
  • USA, PA, Pittsburgh
« Reply #3 on: April 07, 2005, 17:51:12 »
why not wet the cardboard backing, protect the interior fabric side with a towel and then put a piece of plywood on top with some weight - maybe it will go back towards flatter - if not - nothing lost...  just a thought
Bob Happe
Pittsburgh, Pa
« Reply #4 on: April 07, 2005, 18:35:00 »
Can't you get new panel boards? Should be able to use the old ones if they aren't too badly damaged.
1988 560SEC
« Reply #5 on: April 07, 2005, 20:12:50 »
I guess I was trying to avoid pulling off upholstery. I do think the boards are available and not that pricey (35 or something?) I may try Bhap's idea first...Thanks all.
« Reply #6 on: April 08, 2005, 03:04:11 »
James,
The boards are readily available. I just got a pair from SLS in Germany. They are pre-drilled and are even stiffer than the original boards. I paid 33 Euros each.
Here's a link for the diagram available on SLS website.
http://sls.sparebase.de/bin/dbframes.phtml?mid=IN01
Mo
69 280 SL Silver/Black
Ricardo
« Reply #7 on: April 08, 2005, 07:08:25 »
I think the answer that you are looking for is that these masonite like panels will reflatten if you get them wet enough and then secure them flat with some weights...means leaving them off the car for a week, but I would suggest laying them on a wet towel for a day or so and then remove the towel and place enough weight to hold them flat. If they are really warped, try to place some strips under them that will help to push the material beyond the desired position in the opposite direction of the warp. I've done this to correct warped table tops etc. If you try to remove the tex/leather to replace the panel, you may well end up with more damage as the stuff gets brittle after 40 years.
No surprise that your aluminum door has not rusted :D
Ricardo
« Last Edit: April 08, 2005, 07:10:05 by Ricardo »
« Reply #8 on: April 11, 2005, 07:25:10 »
James,
Have you got the door cards off?
If so, have got a flat steel plate held with two screws in the middle of the door inner frame?
« Reply #9 on: April 11, 2005, 08:54:55 »
Hi Naj. No, they are not off at the moment...Perhaps soon. I just have a hard time dismantling things when my spring fever is raging... Is there something I should be looking for?
« Reply #10 on: April 11, 2005, 10:33:29 »
Yes, James,
The plate is secured by 2 screws to the door frame and has a third hole to secure the door card to the door.
A screw fits under the the arm rest so pulling the door from the door frame rather than trying to pull out the door card. Also keeps the card in place rather than dislodging it from the bottom channel.
My original card on the 230 has these holes but it was not drilled thru the covering material.
« Reply #11 on: April 12, 2005, 18:32:23 »
That's interesting Naj. Would that screw be accessed from the finished inner door side? (where the lock, window crank, etc are)... I looked and see no sign of it. And I can tell you, whenever I remove door card, thats not a step. What is noticeable is the warping (or bulging) of the door card is right at the armrest, so its clearly not fastened to anything.
« Reply #12 on: April 12, 2005, 21:06:33 »
Maybe you're simply missing the bolt that goes in under the arm rest on the door.  You pretty much have to sit on the ground with the door open to see it, but it should be there.
« Reply #13 on: April 12, 2005, 22:58:32 »
Could be Rodd. To be clear, are you also saying that when removing your "door card" (I like saying that) you remove a screw or bolt near the armpad?
« Reply #14 on: April 13, 2005, 05:19:18 »
Yes, James,
If this screw is fitted, you will see it under the arm pad.
Are your dood cards original?
« Reply #15 on: April 13, 2005, 08:38:48 »
No screws there. No sign of previous screws either. Original as far as I know -- been the same for 26 years at least!
But it is clear that the rising at the armrests is what is causing bottom to not make it into the channel correctly.
DavidAPease
  • USA, CA, Chico
  • Club Treasurer
« Reply #16 on: April 13, 2005, 10:26:15 »
Hi, James,
I am away and cannot photograph my door for you.  However, this eBay auction:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=10076&item=4543104619&rd=1
has a photo that shows the location of the hole you seem to be missing.  In the "V" formed between the armrest and the pocket, the "dot" that you can see is the hole.  On my car, the screw that fits into this hole has a bright trim ring around it (like the screws under the dash).
-David Pease
'66 French 230SL
-David Pease
« Reply #17 on: April 13, 2005, 10:56:37 »
Yaa, David,
That seems to be the correct location.
Here's a pic of the plate.
Note the li'lle screw in the bottom hole. I used that to mark the card on the 280 which didn't have the hole drilled in it.
Download Attachment: DrLck01.JPG
36.32 KB
« Last Edit: April 13, 2005, 11:02:16 by naj »
« Reply #18 on: April 13, 2005, 11:46:37 »
Nice examples. No screw for sure there on mine. Once I get door off, I will confirm that the plate behing will take a screw. My feeling is that I would still need to do some flattening before securing door card. Otherwise, the tension of the bow might work against me. Thanks all.
By the way, does anyone know if those small rubber thingys that help hold the lock rod mechanism are available? You can see them in Naj's photo.
« Reply #19 on: April 13, 2005, 12:02:43 »
JH,
I don't think MB do those rubber posts any longer but I just got some off Neimoeller.de.
Maybe some US suppliers do them too?
« Last Edit: April 13, 2005, 12:03:30 by naj »
« Reply #20 on: April 14, 2005, 10:02:14 »
Well, I did some exploring. My door seems a little different inside than Naj's. No bracket and a lot more grunge....
If you look closely, there is a small screw hole that might possibly be where original card screwed in. Also you can see how warped the card is on shot #2. Are they supposed to be completely flat or are there some undulations?
Download Attachment: door4.JPG
60.8 KB
Download Attachment: door3.JPG
48.48 KB
« Reply #21 on: April 14, 2005, 12:36:27 »
James,
There may be 2 holes hiding behind the black stuff.
The screw under the arm pad would actually land in the air space below the center member.
Hope you'll be able to see the holes in this pic. Also on a 230SL.
Download Attachment: esn041.jpg
29.85 KB
The door cards on my 230 are flat. No undulations.
I think moisture has taken a toll on your card.
« Last Edit: April 14, 2005, 12:41:06 by naj »
« Reply #22 on: April 14, 2005, 19:07:59 »
Sadly, moisture has taken its toll on my CAR as well as my card.  :?
Yet, still love the old Guzzi. I went ahead and sewed it back up -- doesn't look half as bad from the outside! I can live with it for now. Thanks for all the input.
