Author Topic: Engine Oil?  (Read 8940 times)
rbouch8828
  • USA, MA, Framingham
  • 280SL Mfg date AUG 1969
Engine Oil?
« on: November 05, 2020, 20:21:18 »
Is there any consensus on engine oil for our cars? I saw that Craig at Mercedes Source is recommending Liqui Moly MoS2 Antifriction Engine Oil; 10W-40 Semi-Synthetic. Has anyone had any experience with this oil? Any other recommendations?
RB
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: Engine Oil?
« Reply #1 on: November 05, 2020, 20:54:51 »
Very happy with Valvoline VR1 20w50. It has high zinc.
« Last Edit: November 06, 2020, 16:12:05 by mrfatboy »
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
Re: Engine Oil?
« Reply #2 on: November 05, 2020, 21:30:38 »
I also use this Valvoline, zinc is there. Type marking is VR1.
dirkbalter
  • USA, CA, Corona
Re: Engine Oil?
« Reply #3 on: November 05, 2020, 21:34:54 »
Me too. Valvoline VR1 Racing Motor Oil (high zinc)
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
GM
  • USA, CO, Boulder
Re: Engine Oil?
« Reply #4 on: November 05, 2020, 21:46:39 »
Castrol GTX 20W50
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
franjo_66
  • Australia, NSW, Point Piper
Re: Engine Oil?
« Reply #5 on: November 05, 2020, 22:25:17 »
Here in Australia I use Penrite 20W60, based on the Zinc levels which are higher than the offerings from Castrol, Valvoline etc. It is a mineral oil.
I did dabble with synthetic oils for a while but noticed some minor weeping in gaskets.
Switched back to Penrite and no more leaks
Franjo
1965 230SL Black/Auto/RHD
2005 Porsche Cayenne Turbo
1983 BMW 735i
1986 560 SEC
1991 500SL
1982 Holden Statesman DeVille
mrfatboy
    • Mrfatboy
Re: Engine Oil?
« Reply #6 on: November 05, 2020, 23:16:52 »
I have stayed away from synthetics because I have also seen other who dabbled with them have weeping and slight smoking issues.
Signal Red
4 Speed
Re: Engine Oil?
« Reply #7 on: November 06, 2020, 04:22:01 »
Very happy with Valvoline 20w50. It has high zinc.
I assume your talking about VR1? That is also what I use.
mrfatboy
    • Mrfatboy
Re: Engine Oil?
« Reply #8 on: November 06, 2020, 04:24:27 »
Lol. Yes VR1. My mind types faster than my fingers 🤣
Signal Red
4 Speed
JPMOSE
  • USA, DE, Harbeson
Re: Engine Oil?
« Reply #9 on: November 06, 2020, 12:42:41 »
VR1 or Brad Penn (now Penn Grade).
Best Regards,
J. P. Mose
1968 250SL
1970 280SE 3.5 Cabriolet
1987 560SL
rbouch8828
Re: Engine Oil?
« Reply #10 on: November 06, 2020, 14:18:28 »
Thank you to all!
RB
  • USA, WI, Mequon
Re: Engine Oil?
« Reply #11 on: November 07, 2020, 00:59:15 »
For all my vintage cars (5) I use Rotella T4 Diesel 15w40.  I don't drive them enough to change for mileage (500 mi./year), so I change the oil every other year before they're tucked away for winter.  Has enough ZDDP and is priced well enough I don't have to feel guilty draining expensive oil with no miles on it.  Been doing this forever, back when Rotella was T3.
mrfatboy
    • Mrfatboy
Re: Engine Oil?
« Reply #12 on: November 07, 2020, 02:46:34 »
The Rotella is good stuff also. I used it from 2000 - 2016 until I found VR1. I wanted to move to 20w50. It fit the bill. $23 for 5 qts. One of the cheapest things for a pagoda🤣🤣🤣🤣
Signal Red
4 Speed
Re: Engine Oil?
« Reply #13 on: November 09, 2020, 14:37:01 »
I've used Mobil 1 since my engine was rebuilt years ago.
There's anecdotal evidence repeated by more than a few that suggests if you switch to a full synthetic sometime during the engine's life, you'll exacerbate oil leaks. Well, since I started with this full synthetic and never had issues, it's what I go with. If you haven't used a full synthetic and your engine has not been rebuilt, now is no time to start.
The particular formulation and content of that formulation has changed over the years. It is pretty clear that our engines demand high levels of zinc and phosphorus, lubrication additives that have slowly been weaned out of many motor oils, with the exception of specialty oils.
Last time I bought the Mobil 1, it was on sale at Walmart and was less than USD $25.00 for 5 quarts; this is price comparable to any oil out there suitable for our cars. The only grade of Mobil1 with the requisite level of additives is the 15W-50 formulation. (well, there are some others, such as racing oils, but see the chart. The 15W-50 is the easiest to find, though not always easy.)
Curiously at the local auto parts store, a single quart of the 15W-50 was around $8. Always better to get it in the 5-quart jug, and when it's on sale...
JPMOSE
  • USA, DE, Harbeson
Re: Engine Oil?
« Reply #14 on: November 12, 2020, 13:58:54 »
In summary,  It would be safe to say that one size doesn’t fit all. I agree with Mike on the Mobil 1 15W-50.  It does have extra additives which helps flat tappets.  Plus, Walmart has made it very economical to purchase. I have use this in my 560 SL since day one. Any leaks that have developed are just a matter of age and have been replaced, with the exception of the head gaskets. John also makes a good point about spending excessive money when we only put so few miles on the car per annum.  The bottom line is using what suitable for your engine… My 250 SL is the original engine and has only had the front seal and valve cover gasket changed. As a result, I have chosen not to use a full synthetic.  I have used Brad Penn in the past, which is semi synthetic… But it gets quite expensive. Like John, I find myself spending a fortune on oil and only using the car about 500 miles a year. Hence, the Shell diesel oil is certainly the common sense approach and effective at the same time.  VR1 is readily available and is a great choice, if one doesn’t mind spending the additional money.......after all, we are talking about our “baby”.
Best Regards,
J. P. Mose
1968 250SL
1987 560SL
MikeSimon
  • USA, OH, North Royalton
Re: Engine Oil?
« Reply #15 on: November 12, 2020, 17:08:00 »
I have been using a Mobil 1 10-50 or 20-50 for a while in some of my vintage vehicles with "flat tappets" because of the ZDDP levels. These oils were exempt from the ANSI specifications.
I cannot find them anymore. Mobil has changed their offerings and I don't think neither a 10W50 nor a 20W50 is available anymore.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
Re: Engine Oil?
« Reply #16 on: November 12, 2020, 19:11:23 »
That spec sheet I posted was updated October 2019, so just over a year old. I would have suspected that if they had eliminated the offering the sheet would indicate that, or it would have been updated since then with a different date.
Note that for a number of years, the Mobil 1 oil with the proper levels of zinc and phosphorus was NOT 10W-50, but 20W-50. Also, Mobil1's website lists it as available, it's still on the Walmart website (though not sold by Walmart) and also in stock at Advance Auto, NAPA and others. As I mentioned it isn't the easiest to find, and if you buy it by the quart instead of the jug, expect to pay ~$10.
BTW, the 15W50 is IN STOCK at Advance Auto Parts in N. Royalton, OH...when was the last time you checked there? Also, the Walmart in Parma has a 2-pack (2 x 5 qt) in stock for $69.99. Aisle L22. But, I've found the stock at Walmart sporadic. If you find it, buy it.
« Last Edit: November 12, 2020, 19:23:35 by mdsalemi »
MikeSimon
Re: Engine Oil?
« Reply #17 on: November 12, 2020, 20:48:49 »
I will go to the Walmart in Parma tonight and check.
I have had bad experience with stuff at Walmart showing availability in the store and when you go there - Nothing. We will see.
I think I checked Walmart for 20W50 just 2 weeks ago when I was looking for Startron.
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
Re: Engine Oil?
« Reply #18 on: November 12, 2020, 22:29:34 »
It is "catch as catch can" with Walmart and this specialty oil. Sometimes you may need to go to more than one Walmart. Look for sales. When you find it, buy it, since it may not be there tomorrow. The stock in Parma was listed as "limited".
No modern car needs or uses this, not from any manufacturer.
Any of the local auto parts stores that carry Mobil1 may be able to order it for you in a 5-qt jug.
jameshoward
Re: Engine Oil?
« Reply #19 on: November 22, 2020, 03:14:54 »
This Lucas oil has a high zinc content according to the SDS. It's good value and my car seems very happy with it. I do very few miles per year and it's not expensive. https://www.amazon.com/gp/product/B009M64D8I/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
James Howard
1966 LHD 230SL
franjo_66
Re: Engine Oil?
« Reply #20 on: November 22, 2020, 23:22:57 »
That Lucas Oil has the highest Zinc content that I have seen to date!  2,100 ppm is excellent!
Franjo
1983 BMW 735i
1986 560 SEC
1991 500SL
MikeSimon
Re: Engine Oil?
« Reply #21 on: November 23, 2020, 00:11:57 »
Not being successful at Walmart, I contacted a friend who works for Exxon and he sent me the current Mobil 1 specification chart.
According to this, they do not offer the regular 20w50 anymore. Just a 15w50 with 1300ppm phosphorus and 1300ppm zinc.
The only 20w50 in the 'lineup" is the V-Twin motorcycle oil with 1600ppm phos and 1750ppm zinc.
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
Re: Engine Oil?
« Reply #22 on: November 24, 2020, 16:56:33 »
Is that spec chart the one I posted earlier from their website (which if it is from ExxonMobil's website, assumed to be current)?
Or, did you get an updated version? (the one I posted was dated October 2019)
I did not indicate a 20W50; my experience has been with their only oil for "our" application, and that is the 15W50. That's still on their chart and still available.
MikeSimon
Re: Engine Oil?
« Reply #23 on: November 25, 2020, 23:19:44 »
I guess you have to read between the lines to completely understand posts...
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
JPMOSE
  • USA, DE, Harbeson
Re: Engine Oil?
« Reply #24 on: November 26, 2020, 00:02:15 »
I have just used Mobil1 15W-50 in my 560SL...AND It states right on the back of the container that it applies for a high zinc applications. I think it is fair and reasonable that it is fine for usage with vintage cars with Catalytic Converters, plus earlier.  But, if you want even more zinc, use the other oils named above.....Lucas, VR1, Shell Rotella T4 or Penn Grade.
Happy Thanksgiving everyone!
« Last Edit: November 27, 2020, 17:57:53 by JPMOSE »
Best Regards,
J. P. Mose
1968 250SL
1987 560SL
