Author Topic: exhaust clamp spacer tube A1134920053  (Read 1112 times)
merrill
« on: November 13, 2020, 14:56:40 »
hello
is there supposed to be an exhaust clamp spacer tube at each clamping location  pn A1134920053 ?
in the attached drawing it is item #59 first diagram
in most of the diagrams i have seen it only shows up installed on the first clamp under the passenger seat.
i am thinking of using them on all 3 clamping locations as i have over tightened the most rear clamp and have collapsed the rubber o ring clamp (item #52) second diagram.
thanks in advance
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Re: exhaust clamp spacer tube A1134920053
« Reply #1 on: November 13, 2020, 15:06:50 »
The part list in the EPC says there is only one spacer tube. It is in the place indicated on the drawing only.
