Author Topic: Small tear in soft top  (Read 3058 times)
Bagspacked
  • Ireland, Leinster, Dublin
« on: November 13, 2020, 21:05:22 »
Hi
I have a small mark/tear on my soft top. Curious to know if anyone has come across someone that could fix in California. The tear is quite small but I’m sure there is a local legend that could make this perfect. Any advice greatly appreciated
John Betsch - "SADIE"
  • USA, NY, SOUTHOLD
Re: Small tear in soft top
« Reply #1 on: November 14, 2020, 14:04:12 »
Cant help with  a recommendation.
However, I think you may not be alone.  It seems to be that the piping on the top's edge joins at that spot and I have a very small unraveling of material- small but enough to be annoying.  Thought of covering with a 1/4" wide iron on black patch but am afraid to try.
Anyone have similar issues and recommendations for home repair
JB
JB; 1965 German market SL, Rot Met 571, Summary Code 213 Interior
Bagspacked
« Reply #2 on: November 14, 2020, 14:08:24 »
Cheers Sadie, I have a Spanish mother in law can do magic with a needle and thread. Guarantee there is someone out there that could do almost perfect fix jobs like this
« Reply #3 on: November 14, 2020, 19:08:33 »
You might try German Auto Tops in the LA area. They have been most helpful over the years.
www.gremanautotops.com
Phone  (866) 760-8677
Bagspacked
« Reply #4 on: November 15, 2020, 16:52:59 »
Thanks Jonny
Just sent them an email 👍
paults1
  • USA, FL, The Villages
« Reply #5 on: November 16, 2020, 05:06:39 »
I have a small tear in the same location as yours. I glued, using 3M trim adhesive, a small piece of the top material over it years ago. The patch is approx. 1 inch square with rounded corners. It prevents any further damage.
Bagspacked
« Reply #6 on: November 16, 2020, 15:47:30 »
Cheers
ted280sl
  • USA, NY, New Rochelle
« Reply #7 on: November 17, 2020, 15:45:22 »
This post is not exactly on point but, it might prove to be helpful to some of our members. I recently experienced damage to my soft top and it was covered by my auto insurance. I got a new top installed at a local shop and it was fully covered by my insurance company.
1969 280SLw/original color tan top
Ted280SL
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« Reply #8 on: November 17, 2020, 17:04:03 »
Re insurance coverage for the soft top - check the insurance company first and have them do an inspection and give you a written "out of pocket" estimate.  Up here in Canada our insurance company said they they would replace my top but ontop of the deductible they charged me the depreciated value of the top so it ended up costing me almost the same as a "cash" deal with the local top installer.   It was an MGB top so fairly easy to install so your results may differ.
Ian
69 280SL
65 F-100
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
08 NPS50
12 Pro 4X
RAY
  • United Kingdom, England, Bromley
« Reply #9 on: November 17, 2020, 18:36:03 »
I think you may find that the cause of this problem is the locking mechanism that holds this section of roof in place when you fold the roof down. It tends to come unlocked when folded away and rubs in the soft top box so be sure that it locks in place securely otherwise it will happen again, I know because it has happened to me.
Bagspacked
« Reply #10 on: November 19, 2020, 17:46:47 »
Cheers
paults1
« Reply #11 on: November 19, 2020, 18:48:56 »
That is exactly what caused my top damage. I cut a piece of plastic from a water bottle and I lay against the locking latch when I put the top down.
Bagspacked
« Reply #12 on: November 20, 2020, 14:50:14 »
Thanks for the tip
« Reply #13 on: November 20, 2020, 15:00:18 »
Will look at mine too! I have a small discoloration in that place now.
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #14 on: November 20, 2020, 15:10:58 »
I place vinyl sheets/plastic at all the “hot” spots around the soft top when opening or closing.
Right and left side above fenders.
Right and left at horseshoe hinges
Horseshoe lock.
All of these places rub on the soft top fabric and cause wear and tears.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
