Author Topic: TDC for 123ignition distributor????  (Read 3692 times)
McBenz
  • USA, TX, CELINA
  • Both car and owner from Stuttgart
« on: November 18, 2020, 18:46:56 »
Quick question, do I need to set the #1 cylinder using the timing scale at "0" TDC to install a new 123ignition? OR do I set it to the recommended 35-38 degree BTDC from my old Bosch 051 distributor? The 123ignition instructions say "that before removing old unit, make sure rotor points to #1 cylinder and then remove and drop in new 123. Which I would think is actually the 38' BTDC. Am I really just not getting it ???? Help and thanks.
1965 230 SL (Family Owned Since June 1965)
1974 Porsche 914 2.0L
2000 LX470 100 Series LandCruiser
  • USA, WI, Mequon
Re: TDC for 123ignition distributor????
« Reply #1 on: November 18, 2020, 19:05:14 »
I just put one in my 250 SL.  #1 should be at TDC on the compression stroke (piston at top of cylinder).  Timing mark should be aligned at TDC or 0, as you indicate.  This should enable you to start the car and then use a timing light to set the timing to 30 degrees @ 3K rpm, at least as indicated in my factory specs.
When I installed mine, I noticed my drive gear was not parallel with my rotor in the Bosch distributor as it is in the 123.  This meant the 123 was rotated about 20 degrees clockwise from the Bosch when installed.  Be sure to mark your wires and ascertain that the rotor is coming up (clockwise) on #1.  The firing, and therefore clockwise wire order, is printed on the valve cover.
Not sure if there are differences to the 280 vs. my early 250.
The car runs magnificently.  It ran very nicely before, I was just eliminating future maintenance with the 123, but I could barely feel the car idling at 800 and she revs very willingly.
McBenz
  • USA, TX, CELINA
« Reply #2 on: November 18, 2020, 20:32:33 »
Thank you for your advice. I appreciate it. Looking forward in using the 123ignition. Did you install the Bluetooth version? Any recommendations to set Advance and Map Curves?
dirkbalter
  • USA, CA, Corona
« Reply #3 on: November 18, 2020, 21:42:02 »
I did the Bluetooth on my 280. There is what 123 calls a little "trick". PM me and I can send you the info if needed.
(Car runs great with it)
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
  • USA, WI, Mequon
« Reply #4 on: November 19, 2020, 01:00:50 »
I used stock merc-6-R-V curve 8
I don't really know how the car could run any better, maybe just allow someone a better dyno report.  But, my seat dyno says we're gold.
dirkbalter
  • USA, CA, Corona
« Reply #5 on: November 19, 2020, 01:32:07 »
I wasn't looking for something special either. I just wanted to copy a 051 dizzy curve. But in the tune+ you have to program the points yourself. If you look at point # 5, it is set to 99 instead of 100 which is what 123 calls a trick to program the vacuum advance.
(To the best of my understanding)
Car runs great with this curve. No comparison the my old (rebuild) 051 distributor.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #6 on: November 19, 2020, 08:22:45 »
That's not what I'm seeing in that image.
dirkbalter
  • USA, CA, Corona
« Reply #7 on: November 19, 2020, 15:18:02 »
Ok. And what are you seeing?
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #8 on: November 19, 2020, 15:24:53 »
I need new glasses!  ;D
