Author Topic: TDC for 123ignition distributor????  (Read 6145 times)
McBenz
  • USA, TX, CELINA
  • Both car and owner from Stuttgart
« on: November 18, 2020, 18:46:56 »
Quick question, do I need to set the #1 cylinder using the timing scale at "0" TDC to install a new 123ignition? OR do I set it to the recommended 35-38 degree BTDC from my old Bosch 051 distributor? The 123ignition instructions say "that before removing old unit, make sure rotor points to #1 cylinder and then remove and drop in new 123. Which I would think is actually the 38' BTDC. Am I really just not getting it ???? Help and thanks.
1965 230 SL (Family Owned Since June 1965)
1974 Porsche 914 2.0L
2000 LX470 100 Series LandCruiser
  • USA, WI, Mequon
Re: TDC for 123ignition distributor????
« Reply #1 on: November 18, 2020, 19:05:14 »
I just put one in my 250 SL.  #1 should be at TDC on the compression stroke (piston at top of cylinder).  Timing mark should be aligned at TDC or 0, as you indicate.  This should enable you to start the car and then use a timing light to set the timing to 30 degrees @ 3K rpm, at least as indicated in my factory specs.
When I installed mine, I noticed my drive gear was not parallel with my rotor in the Bosch distributor as it is in the 123.  This meant the 123 was rotated about 20 degrees clockwise from the Bosch when installed.  Be sure to mark your wires and ascertain that the rotor is coming up (clockwise) on #1.  The firing, and therefore clockwise wire order, is printed on the valve cover.
Not sure if there are differences to the 280 vs. my early 250.
The car runs magnificently.  It ran very nicely before, I was just eliminating future maintenance with the 123, but I could barely feel the car idling at 800 and she revs very willingly.
McBenz
  • USA, TX, CELINA
« Reply #2 on: November 18, 2020, 20:32:33 »
Thank you for your advice. I appreciate it. Looking forward in using the 123ignition. Did you install the Bluetooth version? Any recommendations to set Advance and Map Curves?
dirkbalter
  • USA, CA, Corona
« Reply #3 on: November 18, 2020, 21:42:02 »
I did the Bluetooth on my 280. There is what 123 calls a little "trick". PM me and I can send you the info if needed.
(Car runs great with it)
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
  • USA, WI, Mequon
« Reply #4 on: November 19, 2020, 01:00:50 »
I used stock merc-6-R-V curve 8
I don't really know how the car could run any better, maybe just allow someone a better dyno report.  But, my seat dyno says we're gold.
dirkbalter
  • USA, CA, Corona
« Reply #5 on: November 19, 2020, 01:32:07 »
I wasn't looking for something special either. I just wanted to copy a 051 dizzy curve. But in the tune+ you have to program the points yourself. If you look at point # 5, it is set to 99 instead of 100 which is what 123 calls a trick to program the vacuum advance.
(To the best of my understanding)
Car runs great with this curve. No comparison the my old (rebuild) 051 distributor.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #6 on: November 19, 2020, 08:22:45 »
That's not what I'm seeing in that image.
dirkbalter
  • USA, CA, Corona
« Reply #7 on: November 19, 2020, 15:18:02 »
Ok. And what are you seeing?
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #8 on: November 19, 2020, 15:24:53 »
I need new glasses!  ;D
yves
  • France, Poitou-Charentes
  • Happy owner of a 69/ 280 sl , 63 Etype ,55 XK 140
« Reply #9 on: February 14, 2025, 08:32:41 »
To Dirk; i have installed a 123 blue tooth version in my 69 280 and i wonder if the curve you have posted here is the N°8 named by the 123ign shop?
Happy owner of a 69 blue 280SL ,  63 FHC  osb E-type , 55 FHC XK 140 to be restored...
yves
« Reply #10 on: February 16, 2025, 15:02:16 »
I am still confused with the curves....! I thought that at 3000 RPM we should have 30 advance degrees? Am i wrong?
To Dirk: in your schema the max advance is 19° if you have put  0° in the static advance on the app . But in that occurence if i put 6 ° in the static advance i should have 19+6 = 25 °  ... ! am i still correct?
« Last Edit: February 16, 2025, 15:44:34 by yves »
dirkbalter
  • USA, CA, Corona
« Reply #11 on: February 20, 2025, 19:02:49 »
@yves,
My static advance is set to 8 deg. That puts me at about 27 deg total. Both of my cars are running quiet well with that curve. I suppose, I could add a couple of degrees to the centrifugal curve and see if it makes a difference or even improves it.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #12 on: February 20, 2025, 19:38:24 »
Dirk, Thank you for your patience...
I, obviously, do not understand the 99 trick.
My interpretation of the MAP curve was that
- the more opened throttle the lower the pressure
- the curve then provides additional advance
If the pressure in the throttle is somewhere close to 100, the advance is close to 10deg on top of the 27-28 you get from static+"centrifugal".
It is probably wrong logic, because according to what I said, you should be getting more advance from MAP with more opened throttle and lower pressure.
Well, I dropped thinking too much about it, loaded your curves, set the static and enjoying the drive.
Still, I do not get the MAP curve and 99 trick.
dirkbalter
  • USA, CA, Corona
« Reply #13 on: February 20, 2025, 20:46:38 »
Pawel,
before I start talking nonsense, take a look at below tutorial.
https://123ignitionusa.com/curve-tutorial/
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #14 on: February 20, 2025, 21:53:47 »
Thank you!
I must have missed the bit about 100kPa is atmospheric, a zero point. Ok, now it falls better in place.
Thanks again!
dirkbalter
  • USA, CA, Corona
« Reply #15 on: February 20, 2025, 22:28:48 »
Pawel,
attached is the email from 123 when I asked the question.
It has been a while.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #16 on: February 21, 2025, 08:14:23 »
I see...
Thank you again for your kind attention!
