I would like a kind advise on this. I have an elbow on both sides, the upper frames are pointing down. Does not bother me enough to go through a major soft top overhaul (which is what it takes, as I read, to get rid of it) but I was wondering what would experienced Members say to this particular case.
During raising the soft top, the side frames are straight. But when they are straight, the two studs that go into the windshield frame are good 1 to 1.5cm behind the orifices in the windshield frame. When I push up the front of the top, it clicks up a bit, elbows get formed and the studs are in the orifices, so that I can lock the roof. The roof is locked, but with these elbows.
I could move the roof forward, I have 3-5mm space for the rear of the window glasses on both sides. But I am afraid 3-5mm is not 1-1.5cm I need for the studs to engage in the orifices in the windshield.
I followed: glass fit to hard top, soft top fit to glass. Everything fits, except these elbows.
Is there any way to fix it without overhaul of the soft top?
I do not suppose moving the soft top forward 3-5mm will do the trick as I need more movement in the front...
