Author Topic: Clutch lines  (Read 3217 times)
EdwardBernard
  • Canada, AB, Edmonton
Clutch lines
« on: November 24, 2020, 22:40:13 »
My 1964 230 SL had extensive floor replacement, including removal of the clutch lines from master to slave cylinder. and I am left without any idea of where new replacement lines are supposed to run. Does anyone have a schematic? Even a verbal description would help. Thanks!
Bill
Bill Leddy, Edmonton, AB, Canada
1964 230 SL, red, manual, ps
Re: Clutch lines
« Reply #1 on: November 25, 2020, 20:13:12 »
I do not have a manual, so I’m not sure if this helps.
^Peter
Leester
  • USA, VA, Lorton
Re: Clutch lines
« Reply #2 on: November 26, 2020, 18:03:25 »
Hello Bill, I'm working on same issue at the moment but mine is a 280SL and there are differences so I'm not sure I can help much. SLS has some very nice expanded diagrams of parts such as these that you may find helpful.  See:
https://www.sls-hh-shop.de/main/de/25-26-kupplung-4-gg-getriebe-25-a-kupplung-manuell-mechanik-hydraulik-c-3_2348_62
For what its worth, on the 280SL there is a hard line from the master cylinder through the front floorboard, then a hose - like a brake hose, from the end of that hard line to the slave cylinder.
Good luck, Lee
Lee Backus
1963 220SE Cabriolet
EdwardBernard
Re: Clutch lines
« Reply #3 on: November 27, 2020, 00:28:31 »
Thank you both, Peter and Leester! Lee, can you tell me where that hard line goes (high or low?) through the front floorboard, and what that connection looks like? I imagine there must be a grommet of some sort where hard and soft lines meet. For all the many Pagoda photos I've seen, that view is not one of them!
EdwardBernard
Re: Clutch lines
« Reply #4 on: November 27, 2020, 03:24:21 »
Hi again! I just located an excellent website with 18 minutes of superb restoration photos. It shows photos of the clutch lines at 8:36 and 8:49 elapsed time. Link below:
http://www.sltechw113.com/restoration-slideshow-1964-230SL.html
DaveB
Re: Clutch lines
« Reply #5 on: November 28, 2020, 10:07:08 »
Here are a couple of photos, inside and out (1965).
The part number I have for the lower grommet is 110 997 14 81 but it's an old parts book so don't necessarily trust that.
DaveB
'65 US 230sl 4-speed, DB190
rjmarco
  • USA, CA, Alamo
Re: Clutch lines
« Reply #6 on: November 28, 2020, 12:26:33 »
For your info, here is a photo from a few years ago when I had my floor pans replaced.
Rich
Alamo, CA
EdwardBernard
Re: Clutch lines
« Reply #7 on: December 16, 2020, 16:49:01 »
Hello, I just want to thank all of you for taking the time to help me out. Much appreciated!
