A previous owner had installed a big-chassis Becker Europa Stereo, very incorrect for a early sixties car. The installation required that the opening in the dash center piece be enlarged. Fortunately, new center pieces are available from Authentic Classics and other vendors. So, I bought one from Authentic. Gernold provided a radio delete plate and a 230SL emblem. Here is a before and after with everything painted and installed.
With the dash center and the glove box out, it seemed a good time to investigate the heating system, since the heat appeared to be full on all the time. It turned out that the levers on both heater flaps were broken and the heater valve was frozen in the full On position. The fresh air flap was disconnected, and the distributor dash lever was broken. In addition, the paper mache' defrost vents had deteriorated and were barely held together with duct tape. Oh, and the right side fresh air vent was inop because the control rod had separated from the flap.
Well, at least the blower worked.
Fortunately, I was able to find a combination of new and used parts and now have functioning heating, defrost, and vents. The parts tab including various gaskets and shipping came to about $1100.
Cheers,
