Author Topic: Fuel Pump?  (Read 2974 times)
  • USA, West Seattle, WA
  • '69 280SL,Signal Red,
Fuel Pump?
« on: April 10, 2005, 17:43:08 »
I have this fuel pump on the left side of the engine, mounted behind the fuel filter on the engine support arm. It looks like a normal fuel diagphram pump but I can't see how it is driven. Usually these pumps have a plunger or a lever which is actuated by the cam shaft. It moves the diagphram and thereby pumps fuel. But on my engine I can't see any drive mechanism. I'm just curious: The car runs fine and I'm not going to take it apart just to study it. Does anyone know?
« Last Edit: April 11, 2005, 17:58:23 by theengineer »
graphic66
Re: Fuel Pump?
« Reply #1 on: April 10, 2005, 18:44:26 »
I believe you are looking at the fuel damper. It smoothes out the pulses in the fuel system. At least I think that is what it does.
Re: Fuel Pump?
« Reply #2 on: April 11, 2005, 08:06:33 »
If we're all talking about the same thing, Graphic66 is right, it's a damper.  I HAD to take it apart because I thought it was a check valve, but it's not, it's a damper and that's all.  Simply a heavy diaphragm, probably outlast the rest of the car.
Re: Fuel Pump?
« Reply #3 on: April 11, 2005, 17:57:32 »
Thanks Guys! Much appreciated.
Re: Fuel Pump?
« Reply #4 on: April 11, 2005, 21:22:11 »
Hello Guys,
Yes a dampner it is. I believe it's purpose was to reduce surging fuel noise in the fuel feed system.
