Author Topic: Winscreen wiper adjustment  (Read 4265 times)
col320ce
« on: December 11, 2020, 01:15:00 »
I can see the 10mm bolt just off the arm of the wiper motor to adjust the wipers but I can't work out how to stop the initial 'dip' the wipers are making before operating correctly (ie they initially are traveling in the wrong direction when first operated).
What's the correct adjustment for this?
Thanks!
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
And George, the infamous 1992 Ford Laser
col320ce
Re: Winscreen wiper adjustment
« Reply #1 on: December 11, 2020, 02:02:15 »
Worked it out.... There are splines on the bottom of the motor (14mm nut). I just rotated the arm attaching to this and it's stopped the drop before working.
The wipers are just still (just) hitting and I can't get it to go unless the arms are parked higher that what looks correct.
Col
1964 230SL
1965 250SE coupe
« Reply #2 on: December 11, 2020, 20:43:08 »
Thanks!
col320ce, it has been explained on the forum (like, I think, everything...): when the motor arm and the wipers lever are forming a straight line - this is the zero point. When you tighten them together and fit the wipers arms at their zero position - they will go up without dipping.
« Reply #3 on: December 12, 2020, 00:58:37 »
Caution, never work on the wiper linkage with the ignition on. The wipers can activate automatically, if you move past the "parking" position. If your fingers are in the linkage when this suddenly happens, you will get hurt!
col320ce
« Reply #4 on: December 12, 2020, 08:43:35 »
Thanks Joe and Pawel...
The wipers park in a good place and the glove box side is on top.  If I adjust the 10mm bolt that adjusts the sweep start and end points I can only get the wipers not to hit if the park position is "high". They're are only just hitting BTW... And it's the metal part not the rubber.
I've tried moving the wiper on its spline but this makes the park position look very wrong.
I assume there is no more adjustment anywhere else?... I kind of want to move one blade half a spline...
BTW.. Took her out for a drive today... First time she's been drivable since April
Col
1964 230SL
1965 250SE coupe
« Reply #5 on: December 12, 2020, 09:32:48 »
So the complaint is that they are hitting each other? Are they the proper length? Also: the park position in such that the passenger arm is well above the driver's side arm. Drivers arm is close to window seal, the passenger arm is, well, an inch above or so, maybe a bit more.
col320ce
« Reply #6 on: December 13, 2020, 07:47:54 »
Hi Pawel
I worked out what the problem was... There was too much laxity (wear) in the joint where the blade attaches to the arm. I put a washer in there to fill the gap (cut a slit in a copper washer and pushed it in).
Now they don't hit!
Col
1964 230SL
1965 250SE coupe
