Author Topic: How to restore plastic parts.  (Read 5746 times)
« on: December 12, 2020, 18:11:32 »
Thought I would pass this on.
Re: How to restore plastic parts.
« Reply #1 on: December 12, 2020, 19:57:40 »
This is after a month of my fight to make the brake fluid reservoir white again...
« Reply #2 on: December 12, 2020, 21:04:52 »
"Thought I would pass this on......."
Thanks, I recognize this, brilliant.  ;D
^Peter
ejboyd5
  • Southold, NY
« Reply #3 on: December 13, 2020, 00:04:15 »
Not confusing at all. Shvegel is simply confirming the fact that once the container has changed color it's not going back to white.
« Reply #4 on: December 13, 2020, 01:10:00 »
Plastic is surprising porous and absorbs color from liquids very easily. Once it is absorbed, it is not coming back out. Plastic bottles of swimming pool acid will emit a very slight acidic fume over time. Place a gallon near steel parts and you will see within a few months that the steel will have starting rusting. Highly evaporative solvents will also creep very slowly through plastic bottles. That is why most come is steel containers, not plastic.
MikeSimon
  • USA, OH, North Royalton
« Reply #5 on: December 13, 2020, 13:24:08 »
Not only liquid, but light will discolor plastic also.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
RobSirg
« Reply #6 on: December 14, 2020, 00:04:44 »
Great Post ;D - my experience exactly
1962 E Type Jag BRG with Tan
1974 White Alfa Spider 2000
2023 Range Rover
1982 280TE (my daily)
1977 Yellow 911 Targa
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
« Reply #7 on: December 14, 2020, 01:23:06 »
Yes. The bromine (fire retardant) in plastics reacts with UV. You can use commercial hair bleaching peroxide cream to change it back to an original whiter color. Though I would only attempt it on cosmetic items as the plastic is already a brittle 50 years old.
« Reply #8 on: December 14, 2020, 07:19:41 »
Tyler, I tried it actually. No effect. Any specific way you could share to make it work? I tried it on brakes fuid reservoir.
WRe
« Reply #10 on: December 14, 2020, 23:51:13 »
I did that. It did not work.
You say 10% solution and UV? Maybe I missed UV...
Could you describe how exactly you did that? Apparently I missed something...
WRe
« Reply #11 on: December 15, 2020, 17:37:49 »
Hi Pawel,
Peter from pagodentreff.de put it all together in a lockable glas and left it sometimes turning around for some weeks in the sun.
...Wolfgang
« Reply #12 on: December 15, 2020, 19:23:59 »
I see, thank you.
Do you know if he used just the 10% H2O2 as you buy it in bigger bottle, or he further diluted it?
GM
  • USA, CO, Boulder
« Reply #13 on: December 15, 2020, 21:23:47 »
Full strength, undiluted. But you need the "potent" peroxide from a beauty shop, apparently.
I have yet to try this but there is also this - https://www.youtube.com/watch?v=JqCN7VHMtfQ - which I am curious to try
« Last Edit: December 15, 2020, 21:55:04 by GM »
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
« Reply #14 on: December 15, 2020, 21:37:48 »
Thanks. That is where I got mine. Missed UV maybe...
