Author Topic: Lifetime of pagoda plugs  (Read 2995 times)
gwuisman
  • Keep it simpel
« on: April 11, 2005, 13:25:33 »
My car had its annual service after 7000 km’s. The mechanic suggested to change the plugs. I doubted as modern plugs in today’s cars are changed after 20.000 or even 25.000 km’s. The argument of the mechanic was that our engines have a hotter burning and a higher CO % which results in a heavier wear. What are your views on this or experiences with the lifetime of your plugs?
Gerard Wuisman
1970 280 sl
Re: Lifetime of pagoda plugs
« Reply #1 on: April 11, 2005, 13:56:24 »
In my experience, 7000KM is not an unreasonble amount between plugs. That would be about a 2 year span on average for me (but lots of daily starts and short drives) -- and I usually have the points & plugs changed every two years... as part of the general tune-up.
« Reply #2 on: April 11, 2005, 17:00:04 »
Hi Gerard - I change plugs about every 15,000 km, and they still look and perform good at that point. Mind you, the cost is low, so it is probably not a bad idea to change them once a year.
« Reply #3 on: April 11, 2005, 17:07:46 »
I would agree with Cees.  In the old days the usual recommendation was to change plugs and points every 12,000 miles (19,000-20,000 km).  For standard plugs, that would probably be ok.
Modern plugs with dual platium/irridium/etc. tips last much longer than standard plugs, so if you are using them they can probably go 30,000 miles or more.
« Reply #4 on: April 12, 2005, 11:06:36 »
The life of the spark plug is not dependant only on the technology of the plug, but the technology of the engine it's in.  How constant is the air/fuel mixture?  How clean is the throttle body?  How quickly does the engine warm up?  How much oil gets into the combustion chambers (worn valve train or rings/bearings)?  How consistant is the voltage to the plug?
I would assume these things and more contribute to the life of the spark plug.
