Become a
Full Member
Emergency Contact List
Wanted To Buy
Valve spring compressor
Topic: Valve spring compressor (Read 2936 times)
MarkCan
Full Member
Silver
Canada, Ontario, Mississauga
December 16, 2020, 03:56:07 »
I’m looking for MBZ1021 valve spring compressor.
Let me know if you have one.
Mark
Associate Member
Platinum
Canada, ON, Port Lambton
Re: Valve spring compressor
December 16, 2020, 07:08:04 »
Is this for some special application? An ordinary valve spring compressor will work on any 113 cylinder head.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
Full Member
Platinum
Poland, Mazowieckie, Konstancin-Jeziorna
Reply #2 on:
December 16, 2020, 17:30:24 »
Mark, allen No. 5 will do the job - if it is a one-off job, like valve adjustment or dismantling.
See Fig. 7 there. You do not even need the vice-grip.
If not, some ideas here:
https://www.sl113.org/forums/index.php?topic=28717.0
Last Edit: December 16, 2020, 17:37:57 by Pawel66
MarkCan
Full Member
Silver
Reply #3 on:
December 17, 2020, 03:29:22 »
Thanks guys.
I got the head disassembled with the universal compressor. I’m still looking for a proper tool though.
When the time will come to put it all back together, I don’t want to jump through the hoops again.
Wanted To Buy
