Please check out joining the
Emergency Contact List
for help during your travels!
Question and comments on Originality
Lubrication for injection pump
Topic: Lubrication for injection pump (Read 4864 times)
jpressick
Inactive
Regular
USA, VA, Poquoson
December 17, 2020, 20:42:02 »
I have a 250 SL and would like to know if the injection pump is lubricated through engine oil or does it need to be lubricated separately. If so what lubricant should be used?
Full Member
Platinum
USA, OH, Blacklick
Re: Lubrication for injection pump
December 18, 2020, 00:25:20 »
Yours should have the separate oil supply. Confirm this by looking for the screw-in dip stick on the lower rear end of the IP. Your normal engine oil is fine to use in it. It is good to suck the old oil out and add fresh if it has not been changed.
Associate Member
Platinum
USA, WI, Mequon
Reply #2 on:
December 18, 2020, 01:29:00 »
and make sure you check the oil level on the little dipstick (where you fill it), not fill it up to the hole.
