Author Topic: Rocker springs and clearance from valve springs  (Read 1512 times)
Pinder
  • USA, NJ, Edison
« on: December 18, 2020, 02:09:56 »
I took the valve cover off to inspect the top of the engine. I notice some value rocker springs in contact with valve  springs. Is this normal ? I moved the spring around the ball studs to move them away. It puts them a little off center. Is this anything needed to be addressed ? I would think the contact with the valve springs would cause I necessary chatter or noise.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
Re: Rocker springs and clearance from valve springs
« Reply #1 on: December 18, 2020, 06:34:54 »
Good to move them away from each other, but probably not causing noise. Check to make sure the camshaft is not too close to the valve cover hold-down metal straps. This can be a source of noise if they touch.
Pinder
  • USA, NJ, Edison
« Reply #2 on: December 18, 2020, 10:01:11 »
Thanks Joe. Yes the hold down straps were rubbing the cam so i did bend them slightly to provide a clearance.
