Author Topic: power steering box re-seal  (Read 3099 times)
dirkbalter
  • USA, CA, Corona
« on: December 20, 2020, 00:16:11 »
Hello.
As I am attempting to reseal my power steering box, I ran into a problem. While the disassembly started promising, I am stuck, trying to remove the (pitman arm ) shaft.
The shaft moves approximately 3/8 and stops. I tried light tapping with no success. I recognized a retaining ring (see pic) that I cant seem to be able to remove.
My questions to the guys that may have done that:
Any suggestions on how to remove the shaft in general?
Does the retaining ring need to be removed in order to slight the shaft out?
Am I missing something?
Thanks in advance.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
dirkbalter
  • USA, CA, Corona
Re: power steering box re-seal
« Reply #1 on: December 20, 2020, 00:17:20 »
one more
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
WRe
« Reply #2 on: December 20, 2020, 08:40:00 »
do you know chapter 46-27 of workshop manual 1959: https://vdhflipbooks.de/books/WHB/WHB1959-Band-3/#320 ?*
Bring steering shaft in center position, remove retaining ring, knock out shaft.
...WRe
* Registered users can access the flipbooks again if they have applied to join the "Flipbook Lexikon" in their user profile (control center).
dirkbalter
  • USA, CA, Corona
« Reply #3 on: December 20, 2020, 17:12:46 »
WRe,
Thank you much. I think my membership expired and I have to re-register with them again.
My BBB (1959) does not have that section.
However, I was playing with it last night and finally figured it out. Once I start re-assembling I am expecting many more questions to come up.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Pento
« Reply #4 on: March 10, 2021, 14:07:39 »
hi
Can you describe how to remove the valve shaft and insert the seals please
Mark
