Author Topic: 230SL Vertical spare wheel fuel tank  (Read 2044 times)
Lotus211
  • New Zealand, Wellington, Wellington
« on: December 21, 2020, 21:17:45 »
I have a question, did all 230SL's with the 65L tank have the vertical spare wheel well, or only the early models?
Did only the 250/280 have the larger 82 liter tank?
Also are replacement vertical spare wheel fuel tanks available?
1964 Mercedes 230SL
Re: 230SL Vertical spare wheel fuel tank
« Reply #1 on: December 21, 2020, 21:54:42 »
Only the early cars have the spare tire well. Tanks should be available but once the spare tire well is gone then you can use the bigger 82 liter tank.
Lotus211
« Reply #3 on: December 21, 2020, 22:11:18 »
Thanks for your prompt reply Pawel, it appears that only NON vertical spare wheel tanks are only available.
I will endeavour to repair mine. Merry Xmas
1964 Mercedes 230SL
dirkbalter
  • USA, CA, Corona
« Reply #4 on: December 22, 2020, 02:39:53 »
You can get them below as well. Shipping may be a bit to much though.
https://www.rmeuropean.com/Products/1134700601-MFG350-V8736.aspx
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
