Yes, looks like your car is one before the change. I am not sure, however, if the later shifter lever was longer.
Please note: I have change marked in the same place (same chassis) for other elements of the shifter gate down under (!) the shifter lever, such as lever below, housing, spring, etc.. So you may want to investigate further if a longer shift lever will fit the rest of the gate mechanism, in case this change was also about the length of the shifter lever. That is, if you want to replace yours with a longer one.
Maybe someone more experienced will chime in.
