Author Topic: door handle rubber pads... WEIRD!  (Read 2643 times)
jan lauwers
  • Belgium, Antwerpen, Geel
« on: December 31, 2020, 22:19:34 »
I am re-fitting newly chromed door handles. The rubber pads that sit between the handle and the door body have a thick and a thin side. Through trial an error I am convinced that the thick part should be on top... (if not the doorhandle is not horizontal). HOWEVER... The rubber pads have markings 'left' and 'right'... and if you apply them that way, the thin part is on top.
I can just not believe that these pads have incorrect markings, left and right. Also on the original pads! Anybody here who can explain this please?
Happy New Year!
Jan
Jan Lauwers, Geel, Belgium
White 280 SL 1969
mnahon
  • Canada, QC, Montreal
Re: door handle rubber pads... WEIRD!
« Reply #1 on: December 31, 2020, 22:33:34 »
Hi Jan,
Happy New Year.
I went through the same confusion a little while ago and came to the conclusion that the thick side is on top. See
https://www.sl113.org/forums/index.php?topic=31622.msg229909#msg229909
Meyer
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
« Reply #2 on: January 01, 2021, 01:15:17 »
Yes, Jan...,
That's correct so.
Allt these rubber pads carry 111 parts numbers ...
and although I think those should be oriented on a W111 C in the same way as on a W113,
nevertheless, your/our observation is absolutely correct.
So, don't worry,  just use them.
Good luck!
« Last Edit: January 17, 2021, 22:16:45 by 114015 »
col320ce
« Reply #3 on: January 03, 2021, 12:25:57 »
I'm pretty sure they are the other way around on my 111.
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
And George, the infamous 1992 Ford Laser
« Reply #4 on: January 03, 2021, 13:14:34 »
From today's spotted picture from the days...
Doug Rich
  • United Kingdom, England, WESTERHAM
« Reply #5 on: February 03, 2021, 22:26:04 »
Hi Jan, do you have any diagrams of fitting the handles back together please? I have just had mine rechromed and need to fit them back together? thanks for any help, Doug
