Become a
Full Member
Emergency Contact List
Body, interior, paint, chrome, and cosmetic items
Stamped serial number on trunk lid
Topic: Stamped serial number on trunk lid (Read 2020 times)
col320ce
Full Member
Gold
Australia, Victoria, Glen Iris
January 05, 2021, 21:08:10 »
Should there be one on the trunk lid? If so where?
My trunk lid does not fit very well so I'm trying to work out if there is just too much filler where the gaps are or if it has been replaced.
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
Full Member
Platinum
Germany, Nordrhein-Westfalen, Tecklenburg
Re: Stamped serial number on trunk lid
January 05, 2021, 21:21:35 »
No.
Hello Col,
Our SLs usually do not have a stamped body number in the trunk lid and doors or the fresh air scoop.
Only early '63 SLs have that.
col320ce
Full Member
Gold
Reply #2 on:
January 05, 2021, 22:21:37 »
Thanks!
Col
1964 230SL
1965 250SE coupe
Full Member
Platinum
USA, VA, Blue Grass
Reply #3 on:
January 05, 2021, 23:15:31 »
Check the hinges to see if they are bent. Sometimes the wind catches the trunk lid as it is opening and jerks it up, bending the hinges. Once the trunk hinges are bent the gaps and alignment are all out of whack.
- Mike Hughes -ô¿ô-
col320ce
Full Member
Gold
Reply #4 on:
January 31, 2021, 03:31:58 »
I found this hidden number on the hard top in addition to the one under its base closest to the boot/trunk... Just posting as I found it interesting.
Col
1964 230SL
1965 250SE coupe
