Hi All,
Apologies if this has been covered I did try searching the forum before posting and drew a blank.
I have rebulit my front subframe and am going to torque the bolts. This will include upper and lower control arm mounting bolts, subframe mount bolts, lower kingpin bolts, etc.
I have all the correct values available from the BBB but wondered if these values are for dry or lubricated bolts/nuts?
The forum covers cylinder head bolts adequately with a consensus that these should be lubricated. I can't find anything for the subframe / suspension.
Regards
