Author Topic: Oil sump pump  (Read 1719 times)
MarkCan
  • Canada, Ontario, Mississauga
Oil sump pump
« on: January 13, 2021, 02:40:18 »
There are only few bits left on the engine block.
One of them is the sump pump, well a part of it. Please take a look at the attached pic. This part is not budging, it feels like it’s a part of the block, not the slightest movement.
I’ll appreciate your guidance.
Thank you
Re: Oil sump pump
« Reply #1 on: January 13, 2021, 03:36:13 »
I would try moving it sideways back and forth until it breaks free. Use a rubber hammer so that you don't damage to pump housing. I've had a few stuck ones but eventually, they came loose.
MarkCan
Re: Oil sump pump
« Reply #2 on: January 14, 2021, 23:17:04 »
Talking about the stuck one. This pump for sure is.
I assume it is save to use a heat gun on it. Now how deep into the block this assembly actually goes?
Re: Oil sump pump
« Reply #3 on: January 15, 2021, 08:25:35 »
Good advice from Dan, rotate it back and forth.
