Author Topic: Front Axle and Steering Gearbox  (Read 1562 times)
Mpgeslak
  • USA, GA, Greensboro
« on: January 13, 2021, 21:05:34 »
Hi All,
Two questions I am looking for assistance with:
1. I am trying to locate where on the Front Axle the serial number is stamped.   Based on the Data Card, it should be stamped on both the left and the right side.  I have looked everywhere, but cannot find it.
2.  Will a steering gearbox with part number 112 461 0501 from a 280SE fit in my 250SL?
Any help would be appreciated.
Michael
Re: Front Axle and Steering Gearbox
« Reply #1 on: January 14, 2021, 16:35:40 »
The steering box from a 280SE should be the same as for your pagoda. However you may need to use the original pitman arm from the pagoda steering box. Look for the I.D. # cast on the pitman arm to identify them.
Mpgeslak
« Reply #2 on: January 14, 2021, 22:29:57 »
Thanks Joe, I appreciate the insight.
