Author Topic: install the transverse spring on a rear axle  (Read 1710 times)
pj
  • Canada, ON, London, Ontario
  • 1965 230SL
    • my home page
« on: January 15, 2021, 13:58:32 »
This photo is from Dan's shop (BenzDr)
Peter J
1965 230SL #09474 named Dagny
2018 B250 4matic named Rigel
Re: install the transverse spring on a rear axle
« Reply #1 on: January 15, 2021, 16:08:31 »
I've attempted to explain how I remove the transverse spring and hopefully this picture will help out.
 Loosen the two screws on the right-hand bracket and then pry upward with a crowbar to relieve the tension on the spring. Carefully remove the right side screw and let the bracket swivel down out of the way. The spring will simply drop out of place. No need for spring compressors or anything else.
My thanks to Peter for posting my picture.
