Author Topic: Bundt wheel valve stem parts  (Read 2999 times)
GM
  • USA, CA, San Pedro
« on: January 18, 2021, 05:48:34 »
And now for something completely different...
I've found a great deal on some original Fuchs bundt wheels and have been cleaning them up to prepare them for powder coating.
I've read about the original wheels require/use a unique metal tire valve stem (of course they do, 107-400-00-13) which is expensive to replace (of course they are, $50-60 each). The existing valves are fine, but will have to be removed for the powder coat process, so I thought it might be a good idea while they are out to replace the rubber seal on them. However, I'm having no luck finding anything but the entire valve.
Anybody know what I'm talking about here and where I could find some fresh rubber (or Viton) seals for these valve stems?
Thanks!
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
Re: Bundt wheel valve stem parts
« Reply #1 on: January 18, 2021, 15:56:12 »
I got mine from Tom at the Classic Center.  I don't remember what I paid.
lowpad
  • USA, CT, New Preston
« Reply #2 on: January 20, 2021, 04:32:57 »
1966 230SL (6/66 build)
French export
4-speed manual
158 Exterior / 040 Hardtop
2001 SLK230
1996 Porsche 993
1991 Acura NSX
« Reply #3 on: January 20, 2021, 14:59:10 »
That's not what they sold me although it is what I was expecting.  What I got was a metal stem encased in rubber.
GM
« Reply #4 on: January 20, 2021, 17:48:37 »
Thanks lowpad.
I just spoke with my dealer parts guy and he confirmed that there is no separate rubber o-ring for the valve stem sold by MB. I guess I'll remove the old one and try to find a suitable replacement.
Here's what the original looks like with the piece that slides into the groove of rim
« Last Edit: January 20, 2021, 18:24:56 by GM »
Gary
1971 280SL - Sold
Black MB Tex
lowpad
« Reply #5 on: January 21, 2021, 04:43:09 »
Since the parts are cheap, I just wound up ordering several on Amazon until I found one that fit.
French export
4-speed manual
2001 SLK230
1996 Porsche 993
1991 Acura NSX
WRe
« Reply #6 on: January 29, 2021, 09:25:54 »
GM
« Reply #7 on: January 29, 2021, 18:01:24 »
Thank you, Wolfgang!
Gary
1971 280SL - Sold
Black MB Tex
GM
« Reply #8 on: March 16, 2021, 18:17:33 »
Just to close out this issue for future needs, I tracked down suitable replacement gaskets/seals for the original bolt-in valve stems used on the bundt wheels.
The supplier is Haltec Corporation in Ohio (800)321-6471
Part number is G-QS-SB
Gary
1971 280SL - Sold
Black MB Tex
