Author Topic: Rosette for Glove Box..  (Read 2311 times)
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« on: January 20, 2021, 23:20:08 »
hello all, I'm planning to install another radio in my 230sl and while I've got the glove box out, I thought I'd install the little rosette that's been missing since I've owned the car. The only one I can find (CONUS) is from Authentic Classics: https://www.authenticclassics.com/Chrome-Glove-Box-Lid-Arm-Rosette-or-Bezel-230SL-p/auth-008064.htm. These little things are expensive! :P. Does anyone know of an alternative source?
Re: Rosette for Glove Box..
« Reply #1 on: January 20, 2021, 23:33:10 »
Charles,
I am at exactly the same spot as you and about to change over my radio.
I purchased a rosette a few years back from, at the time, the only supplier in US and I can tell you it was a whole lot more than what they are charging now. The following two appear to be the only ones at the moment.
And you think Authentic Classics are expensive.  Have a look at SLS Germany and convert
Authentic $39
SLS Germany 33 Euro.
https://www.sls-hh-shop.de/main/en/mercedes-230-280sl-w113-/68-a-dashboard-covering/escutcheon-dull-for-link-rod-glove-box-p-134335
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
dirkbalter
  • USA, CA, Corona
« Reply #2 on: January 21, 2021, 00:26:55 »
Here they are for less, but alum.
http://www.pagode-markt.de/
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
sandcrab59
  • USA, MA, Lunenburg
« Reply #3 on: January 21, 2021, 13:52:39 »
At one of the blacklicks I purchased a couple of sets from Dave Gallon from southern Calif.
If you can reach him he might have them. They were no where as expensive as posted above.
Tom M
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #4 on: January 21, 2021, 16:19:05 »
Garry/Dirk/Tom, thanks guys. I sent Dave Gallon and Mehmet a PM regarding the rosette.
I found a post from Ctaylor (dtd 3/6/2015) that provides outstanding instructions for installation of the rosette: https://www.sl113.org/forums/index.php?topic=22023.msg157124#msg157124. I gotta admit that I'm beginning to lose heart after learning the door has to be removed - realigning the door, the glove box shell, and the rosette isn't going to be easy..
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #5 on: January 21, 2021, 19:52:24 »
I remember from an old post that there's a clip that secures the Map-Light wire to the bottom of the glove box after it exits at the bottom of the door. Does anyone recall seeing such a clip or know whether its available?
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #6 on: February 01, 2021, 01:45:08 »
well I went ahead and ordered a rosette from Authentic Classics since I needed a dash speaker and a couple of other things from them. I installed the rosette today and thanks to Ctaylor's instructions, realigning the glove box door wasn't that bad - just had to go slow and take care not to scratch the door or dash. I'll install the new dash speaker once I replace the broken bulb holder on the heater control lever. Thanks again to Joe (JA17) for the bulb holder!  :)
« Last Edit: February 01, 2021, 02:58:03 by Charles 230SL »
