Author Topic: installing firewall insulation  (Read 2392 times)
CJHenderson
  • USA, AR, Benton
« on: January 24, 2021, 13:54:59 »
What type adhesive will I need to install the firewall insulation?
1950 MG-TD
Vander
  • USA, OH, Columbus
Re: installing firewall insulation
« Reply #1 on: January 24, 2021, 14:31:37 »
If you buy the pre-cut ones, like from Authentic Classics they come with self-adhesive backing. No additional adhesive is required.
sandcrab59
  • USA, MA, Lunenburg
« Reply #2 on: January 24, 2021, 16:52:34 »
As recommended to me by my Mercedes (private) mechanics in Sarasota.
I use from NAPA stores,
3M Yellow super weatherstrip and gasket adhesive.
Part # 08001
I used it my firewall pad and the insulation that goes under the hoods on my Diesels cars.
Tom M
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
CJHenderson
  • USA, AR, Benton
« Reply #3 on: January 24, 2021, 21:16:40 »
Super thanks for the recommend
1950 MG-TD
« Reply #4 on: January 25, 2021, 04:26:42 »
I used Weldwood Vinyl top and tonneau adhesive.  It is a high temperature contact cement.
LA 280SL
« Reply #5 on: March 04, 2021, 03:25:08 »
What supplier do you fellas recommend to purchase a replacement from?
col320ce
« Reply #6 on: March 04, 2021, 07:39:43 »
I think authentic classics do the best reproduction of the diamond pattern...
They're also not too expensive compared to other suppliers.
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
