Author Topic: Grill assembly screws  (Read 2509 times)
col320ce
« on: January 26, 2021, 08:26:47 »
Hi all...
Are these the correct screws and assembly of the front grill? I have trouble getting the grill in and out as the nuts on the extreme left and right get in the way. It also looks like there is an extra washer being used on the star. The car goes off to the painter later this week and the dimensions are dictated buy the grill so I want to get it perfect (the nose has been damaged in the past and needs to be moved a little).
Thanks!
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: Grill assembly screws
« Reply #1 on: January 26, 2021, 09:36:14 »
It’s hard to tell what is exactly going on with your grill with those pictures(locations, etc). Can you post better?  Here is a grill assembly screw kit from Authentic Classics.
https://www.authenticclassics.com/Grille-Screw-Kit-Mercedes-230SL-280SL-190SL-300SL-p/auth-003000.htm
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
« Reply #2 on: January 26, 2021, 10:20:43 »
Colin is after the correct screws for the cross grill members to the surround and and star connections. The Authentic Classic set is for the fitting of the grill to the body.
Unfortunately I don’t know the din of the screws needed. Alfred Esser may know.
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
mrfatboy
    • Mrfatboy
« Reply #3 on: January 26, 2021, 10:27:12 »
Maybe this will help. Here is Authentic Classic’s screw list. Scroll down to “Grille”.
https://www.authenticclassics.com/Chrome-Hardware-Listing-for-230SL-250SL-280SL-p-p/pagoda-113-chrome-display-page.htm
Signal Red
4 Speed
col320ce
« Reply #4 on: January 26, 2021, 20:54:52 »
Thanks everyone... I think I understand how it goes together now.
Does the grill normally slot in fairly easily?
Col
1964 230SL
1965 250SE coupe
kampala
  • USA, CA, Beach Cities
« Reply #5 on: January 26, 2021, 22:38:48 »
download the attachment in this post from Alfred.
https://www.sl113.org/forums/index.php?topic=6554.msg40953#msg40953
250sl - later - manual
280sl - 1971 - Auto - LSD
col320ce
« Reply #6 on: January 27, 2021, 00:31:59 »
Perfect!!
Col
1964 230SL
1965 250SE coupe
