Author Topic: Wheel  (Read 2992 times)
Peter h
  • Germany, Rheinland-Pfalz, Enkirch
Wheel
« on: January 26, 2021, 14:53:34 »
Here's something to play in corona times.
Foldable spare wheel from the w203 or SLK incl. special cover. You have the original look and save space.  8)
The alternative for 15 inch rims....
« Last Edit: January 26, 2021, 15:25:15 by Peter h »
08.68 280sl automatic white 717 G  blue MB Tex
09.68 280sl  4-speed, now 5-speed Getrag 180 G dark green MB Tex
Merc_Girl
Re: Wheel
« Reply #1 on: January 26, 2021, 21:39:16 »
I had similar in my old SLK.
It’s quite entertaining to watch when you deflate again, a lot of popping noises! Fabulous piece of engineering
230SL
Re: Wheel
« Reply #2 on: January 27, 2021, 05:38:29 »
https://www.youtube.com/watch?v=HTYR2e_E7Lk
Peter, does the TÜV approve this spare wheel in a W113?
Peter h
Re: Wheel
« Reply #3 on: January 27, 2021, 06:33:41 »
Why not, Alfred?
Re: Wheel
« Reply #4 on: January 28, 2021, 04:43:33 »
Do you no longer need a "Unbedenklichkeitsbescheinigung" from the car manufacturer or the wheel manufacturer to get it recorded in your car papers?
Peter h
Re: Wheel
« Reply #5 on: January 28, 2021, 05:28:26 »
The 15 inch tires are entered in the papers.
It is not necessary for the spare wheel.
Re: Wheel
« Reply #6 on: January 28, 2021, 06:36:22 »
👍 thanks, learned something new!
Merc_Girl
Re: Wheel
« Reply #7 on: January 30, 2021, 01:35:34 »
Must admit I’m totally confused
I’ve never known an MOT centre, UK, to check spare tyres, other than you have one with some tread!
I guess different countries have different legislation.
My BMW has no spare at all, so surely something is better than nothing 😁
230SL
MikeSimon
  • USA, OH, North Royalton
Re: Wheel
« Reply #8 on: January 30, 2021, 16:42:01 »
A lot of OEMs are doing away with spare wheels. My Audi has a compressor instead. That works fine with a simple flat tire, but not with a major blowout. I have always despised even the economy spare with the speed limit.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
Merc_Girl
Re: Wheel
« Reply #9 on: January 31, 2021, 21:09:25 »
My BMW has silly run flats which they also provide a can of foam just to really mess up the tyre so can’t be repaired afterwards even if it may have been beforehand!
 As you say Simon, if you have a big blow out or damaged the wheel itself, you are rather stuck until a recovery vehicle arrives 10hrs later!!
I still don’t understand however, why there is a question over Peter using the collapsible tyre though, given MB use this style of spare tyre as standard in many of their cars (albeit I’m not sure if this is still their practice?)
230SL
Peter h
Re: Wheel
« Reply #10 on: February 01, 2021, 05:04:50 »
Yes, once the foam has been filled in it is very difficult to save in tires later.
With the 15 inch rims it is no problem to find a cheap replacement tire, they are modern dimensions.
Since I can't get the original 15 inch in the trunk, the folding tire makes sense for me.
