Author Topic: Fuel flow - short fuel pump -1965 230 SL Automatic  (Read 5601 times)
Klaus Pieper
  • South Africa, KwaZulu-Natal, Westville
Re: Fuel flow - short fuel pump -1965 230 SL Automatic
« Reply #25 on: March 03, 2021, 12:52:49 »
It has been a while since I last communicated, but I am pleased that progress has now been made.
As I was unable to source any shims from a M-B dealer, a local engineering firm manufactured 0,2mm shims at a very reasonable price (1.20 USD each) and also of fair quality.  Originally there were 3 shims on the WRD totaling 0.6mm.  It required two additional shims of 0,2mm each for the warm-up process to work satisfactory.  It is not 100% perfect yet, but the base is set and after a bit of fine tuning the car should run well again.
Thank you all for your help, especially mrfatboy who more than sat me up on the correct path.
