Author Topic: Pre painting final questions - grounding and specific item colours  (Read 3877 times)
col320ce
Hi everyone
The car is very naked and back to bare metal and is off to the painters very soon.  I have a couple of questions about the original/correct features that I'd like to replicate.
Ground points:
On the relay panel the LHD earth is the second hole closest to the fire wall. Is this the same on the RHD car?
Are the earthing points in the boot left bare (ie with a 30mm sticker placed before painting?)
Is the battery negative supposed to have a sticker too?
I can't see an earthing point at all on the RHD side of the RHD engine bay (and I didn't take enough pictures before removing the wiring harness) ... is this correct?
Battery tray colour that the battery sits on ... is this dark grey or body colour?
Body plate on the relay panel - is this painted on a 1964 230SL?
Can't wait to post some progress photos of the painting!!
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
And George, the infamous 1992 Ford Laser
doitwright
  • USA, IL, Willowbrook
Re: Pre painting final questions - grounding and specific item colours
« Reply #1 on: January 29, 2021, 01:05:24 »
Not sure this will give you the answer you are looking for however, on the old Motoring Investments website, look for the “My Mink” car. I believe he talks about and shows photo of the bare grounding points.
Frank Koronkiewicz
Willowbrook, Illinois
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #2 on: January 29, 2021, 01:18:56 »
hello Col, not sure about the battery tray color (mine is satin black) but the body plate on the relay panel should be the same color as the car.
col320ce
« Reply #3 on: January 29, 2021, 12:26:07 »
Thanks Frank and Charles .. I'm scouring Motoring investments in search of answers!
Is this correct that the stamped body number is also not painted on a 230SL (most of the cars on the motoring investments site are 280SL's)?
Col
1964 230SL
1965 250SE coupe
doitwright
« Reply #4 on: January 30, 2021, 06:46:03 »
Yes. Not painted.
Frank Koronkiewicz
« Reply #5 on: January 30, 2021, 10:54:13 »
Just not to forget the ground points in headlights wells and one for the wiper motor.
col320ce
« Reply #6 on: January 31, 2021, 12:04:26 »
I had found the headlights earths but I've gone through the wiring harness and there isn't an earth in my RHD wiper motor.  The only earths my harness has are:
2 boot/trunk
LHS rear cabin just before going into the boot/trunk area
2x headlights
Cold start solenoid
Relay mounting board
In dash near cluster
Plus the main engine earth and negative battery connection
Interestingly there were a couple of areas that had stickers in the doors (photo attached) ... can't think what they were for as these guys didn't have any electrics in the doors that I can think of??
Col
1964 230SL
1965 250SE coupe
« Reply #7 on: January 31, 2021, 12:28:12 »
Perhaps this ground point for wiper motor does not exist in RHD. In LHD it is as per the arrow.
johnk
  • USA, OH, Avon
« Reply #8 on: January 31, 2021, 13:33:13 »
It’s primed but not color coated
« Last Edit: February 01, 2021, 12:04:21 by Peter van Es »
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
