Author Topic: starter motor - car not started in 15 years  (Read 2482 times)
Bossjoe
« on: January 30, 2021, 22:46:44 »
Hello. So as a "covid project" I decided to drag my old 1968 250 SL out of the barn and attempt to restore it to drivable condition. When I last drove it - over 15 years ago, it ran fine. My first tasks in the restoration was to drain all fluids: gas, oil, coolant, etc. Some mice had gotten to some of the wiring, so I repaired what I could, replaced spark plug cables, etc. I replaced the spark plugs, squirting a bit of oil into the cylinders as I went along. I manually turned the engine to insure that it wasn't seized. It moved remarkably easily. I replaced all of the fluids (The radiator, unsurprisingly, is leaking - but that will be another topic). I figured that it was safe to try to turn it over. I left the old battery in and hooked up a battery charger to the terminals. I turmed the key, heard what I assume is the fuel pump humming lightly. The lights worked. I tried several times to start the car. The starter moaned - it would crank once every few seconds, then I'd hear a click and it would die out. I'd let it sit a minute and try again, with the same result. I tried it maybe 5 times with the same result. The battery charger has plenty of amps, so I doubt that it was a power issue. So, my question is: Do I have a bad starter? Is it possible that there's something that has the engine not quite seized but kind of stuck? Is there a potential electrical issue?
Any thoughts would be appreciated.
Thank you.
ejboyd5
  • Southold, NY
Re: starter motor - car not started in 15 years
« Reply #1 on: January 30, 2021, 23:40:25 »
Your battery has lost it oomph. Replace it and try again.
Nicolas Aristodemou
  • Cyprus, Lefkosia, NICOSIA
  • 280SL Auto 1970 W113, 380SL Auto 1982 R107
« Reply #2 on: January 31, 2021, 12:43:18 »
A 15 year old battery is no good whatever charger you connect to it. Try a new battery and you should have no problems cranking the engine.
Nicolas Aristodemou
Nicosia - CYPRUS
280SL Auto 1970 US spec (W113), 380SL 1982 R107, Citroen DS23 Pallas 1973, Triumph TR4 1963, Triumph Stag 1973, Mini Cooper S Mk1
1965, Jaguar 3.8 Mk2 1962, VW Beetle 1978 Karman Converible, 1987 Ferrari 328GTS
Bossjoe
« Reply #3 on: January 31, 2021, 17:48:22 »
Thank you Nicolas.
« Reply #4 on: January 31, 2021, 17:49:27 »
Yes you need a fresh battery. Most battery chargers are not really up to the task of starting a car on their own.
Bossjoe
« Reply #5 on: January 31, 2021, 17:50:21 »
Thank you ejboyd5
Bossjoe
« Reply #6 on: January 31, 2021, 17:51:05 »
Thanks Joe.
