Author Topic: well, looks like I'll need a radio plate too (230SL)  (Read 3427 times)
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« on: February 02, 2021, 20:14:21 »
I've got a slimface Europa TG on the way from Becker Autosound and I just discovered (like an hour ago) that my radio plate has been cut to fit a later (larger DIN) radio. Since I have a 230/250 radio plate, I just assumed I had a slimface radio in the car- it never occurred to me that a PO had cut the plate - until I measured it....rats!
« Last Edit: February 02, 2021, 22:30:19 by Charles 230SL »
Re: well, looks like I'll need a radio plate too (230SL)
« Reply #2 on: February 03, 2021, 00:15:21 »
Charles,
Bud's and Authenticclassic should have this dash piece as well.
Ask them.
Or you'll find an original one (NLA by the way): A113 689 0139.
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #3 on: February 03, 2021, 01:25:47 »
Charles, Bud's and Authentic classic should have this dash piece as well. Ask them. Or you'll find an original one (NLA by the way): A113 689 0139. ;)
Yes, I know - its just a hassle to have to match/buy the paint, get my paint 'stuff together, and spray a new one. I've got some dark blue (DB 332) leftover from when I sprayed the wheels and hubcaps..but it'll need to be an exact match with the dash and glovebox door - which with my luck, it won't be :(.  no big deal, I just wasn't expecting the aggravation.
« Last Edit: February 03, 2021, 12:56:21 by Charles 230SL »
Rolf-Dieter ✝︎
  • Canada, ON, London
« Reply #4 on: February 03, 2021, 05:05:38 »
Charles, I am sure you will find your radio plate. I’ve not turned my radio on in 7 years, I prefer to listen to my engine, in time I am certain you will too.
If you do need a radio, use your cell phone wireless with this have a peek below. I have one for 5 years and love it when I do like to listen to my own music :)
Dieter
—-> https://www.amazon.ca/Jawbone-JAMBOX-Wireless-Bluetooth-Speaker/dp/B004E10KI8
scoot
  • USA, CA, Altadena
« Reply #5 on: February 03, 2021, 16:27:24 »
Or you can put in a big-face Becker.  I am sorry this has happened, particularly after you spent $$$ for what I assume is a nice TG.  Post pic of radio.
Scott Allen
'67 250 SL (early)
Altadena, California
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #6 on: February 03, 2021, 16:57:45 »
I took out a big-face Europa MU (which I mistook to be a slimface). I figured since I had a radio plate it was a slimface - I didn't realize the plate had been cut to accommodate a big face radio. I've not received the TG yet - I'll ask Tom to send a picture before it ships.
scoot
  • USA, CA, Altadena
« Reply #7 on: February 03, 2021, 17:02:30 »
You might see if you can cancel your order unless you are planning on switching the dash metal plate...
Scott Allen
'67 250 SL (early)
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #8 on: February 03, 2021, 18:08:21 »
hey scoot, I plan to get a new radio plate for the Europa TG - https://www.authenticclassics.com/Mercedes-230SL-250SL-Dashboard-Radio-Mount-Plate-p/auth-003066.htm.. I just hope I don't run into anymore surprises
scoot
  • USA, CA, Altadena
« Reply #9 on: February 03, 2021, 18:36:06 »
I'm glad you are going that direction.  Much better to have an actual small-face radio in the dash.  Yay!
Scott Allen
'67 250 SL (early)
« Reply #10 on: February 03, 2021, 19:08:13 »
Quote
Yes Charles,
Definitely!
Go for it!
Thumbs up!  ;) :D
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #11 on: February 12, 2021, 18:57:41 »
The new radio plate from Auth Classics arrived yesterday. Using the old plate as a template, I drilled holes for the chrome trim, then sanded and primed it. I plan to spray it dark blue/332 over the weekend. The Europa TG from Becker Autosound will be here next week so the paint will have at least 3 to 4 days to harden. Becker Autosound sent some pictures of the radio but they're not very good.. Tom Mitchell sounded pretty busy and I didn't want to bug him for more pictures.
« Last Edit: February 12, 2021, 20:04:39 by Charles 230SL »
scoot
  • USA, CA, Altadena
« Reply #12 on: February 12, 2021, 19:49:38 »
Pics look good to me!  At least it is the right radio!
Yay for your project.
Scott
Scott Allen
'67 250 SL (early)
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #13 on: March 03, 2021, 23:07:13 »
I've been side-tracked these last couple of weeks but finally managed to install the Europa TG. It looks good, sounds good, so I guess this concludes my Winter project ;)..
DaveB
« Reply #14 on: March 03, 2021, 23:55:23 »
It looks just right and will probably work great for decades. Worth the effort.
DaveB
'65 US 230sl 4-speed, DB190
