Author Topic: Door panel install- proper placemant?  (Read 1778 times)
jzearfoss
  • USA, MT, Libby
« on: February 04, 2021, 20:31:45 »
In the photo you will see the door panel test fitted on the door sitting next to the clips that secure the window felt along the top interior lip of the door (yellow arrow).  You will also see the aluminum trim piece (red arrow) placed along the top of the window opening.  I have the clips that are needed to secure the trim piece to the felt clips.  My question - is the door panel supposed to remain as you see it in the photo or is it supposed to fit into the felt clips along with the aluminum trim piece?
1968 280 SL (AT)
2000 BMW Z3
1962 Pontiac Grand Prix
1951 Studebaker Commander
1937 Plymouth.
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: Door panel install- proper placemant?
« Reply #1 on: February 04, 2021, 20:38:47 »
When I take my door panel off the chrome trim is always attached to the panel. When placed back on I just hook into clips.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
« Reply #2 on: February 04, 2021, 21:32:57 »
I think the door panel lip goes down into the clips. Then I hammer in the chrome. It is probably the wrong way but I have not damaged anything so far. In any case, panel goes into the clips and so does the chrome.
TJMart
  • USA, NC, Matthews
« Reply #3 on: February 05, 2021, 17:21:41 »
It should fit right next to the trim piece. If you leave it the way it is in the picture the chrome trim piece that attaches on the door will not fit.
Tony
1970 280SL, 4 Speed
