Author Topic: Toothed washer, adjuster at upper ctrl arm  (Read 1518 times)
CJHenderson
  • USA, AR, Benton
« on: February 06, 2021, 21:23:10 »
Does the raised tab on the toothed washer, adjuster at upper ctrl arm face the threaded bushing or face away from it?
1950 MG-TD
Re: Toothed washer, adjuster at upper ctrl arm
« Reply #1 on: February 06, 2021, 21:36:45 »
I think it faces the threaded bushing as it is means to turn it to be able to adjust the whole thing. It fits the cut out in the bushing and turns it so that it moves back and forth to fine-tune the caster.
mbzse was advising to set this bushing "in the middle" position for this caster fine-tuning (not adjusting, just fine-tuning).
« Last Edit: February 06, 2021, 21:41:16 by Pawel66 »
PeterPortugal
  • Portugal, Faro, Lagoa
« Reply #2 on: February 07, 2021, 08:44:30 »
I just fitted mine back and came to the same conclusion as Pawel. That the protrusion on the washer should fit into the notch on the bushing.
1963 220se Cabrio
1968 280se Coupe
CJHenderson
  • USA, AR, Benton
« Reply #3 on: February 10, 2021, 00:01:34 »
Thanks, I had no clue and I did do it wrong. Thanks again for setting me on the right path.
1950 MG-TD
