Author Topic: 1970 280SL Carpet Snaps?  (Read 7847 times)
Re: 1970 280SL Carpet Snaps?
« Reply #25 on: February 13, 2021, 00:45:41 »
Yes, on the 49er picture they seem to be nickle matt, but I wonder if it is because of wear.
As for 17mm: I did some search already and already found the male parts with DOT letters even here. The upper part - I saw several standards, including 17mm. One may do some cheating and use DOT marked male part with other, not DOT, but 17mm top part.
49er
  • USA, CA, El Dorado Hills
« Reply #26 on: February 13, 2021, 02:44:35 »
The “button” is polished and this photo was taken of one on the original carpet that was up under the dash which has minimal wear. Picture number 2 is of the new “button” and the 3rd is of the original floor "stud"
John
1969 280SL 003820
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #27 on: February 13, 2021, 02:49:32 »
@49er
Can you confirm that the cap/button in your first pic is 17mm in diameter?
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
49er
« Reply #28 on: February 13, 2021, 03:18:10 »
@49er
I’ll check it for you tomorrow morning. Cold and dark out in the garage now ;)
John
1969 280SL 003820
« Reply #29 on: February 13, 2021, 09:52:48 »
John, thank you for the pictures - fantastic help! Do I recall correctly that your 280SL was 1968?
49er
« Reply #30 on: February 13, 2021, 16:41:21 »
 Hello Pawel, always glad to be of help anyway I can on some of these originally issues that come up. My car was built (according to VIN) in early July 1968 but did not make it here to California until early September 1968 when it became a "1969" model. The car had no headrests so it is essentially a '68 but registered as a '69. Mrfatboy, 17mm it is.
John
1969 280SL 003820
« Reply #31 on: February 13, 2021, 17:47:52 »
Thank you!
Your car has the "early" mechanism for snaps, as you showed: rubber washer + male snap part. :) As per my theory it this mechanism might have been replaced with the black Druckknopf, I think. Maybe.
Desertpagoda
  • USA, AZ, Tucson
« Reply #32 on: February 25, 2021, 00:17:12 »
R these reusable? I have an old carpet set with them.
kb
mrfatboy
    • Mrfatboy
« Reply #33 on: February 25, 2021, 01:00:40 »
Not really. However, I would think you could at least salvage the most important part - female receiver part that says “Dot Durable”. Then just get a new 17mm button head and put them back on the carpet.
Signal Red
4 Speed
« Reply #34 on: February 25, 2021, 06:21:32 »
I think you could try to drill out the DOT marked part, like any rivet. 17mm caps you can just buy it is one of the standards.
neelyrc
  • USA, AL, Birmingham
« Reply #35 on: February 26, 2021, 03:33:30 »
The cap I have has a chrome like finish. You would have to compare to 49er’s picture above. You could also compare with the snap on the spare tire cover. I don’t know if the would be the same.
Maybe it’s a brushed nickel or stainless finish..........
Just to finalize this one point.  The original 17mm carpet snaps are identical to the 17mm snap on the spare tire cover.  It is definitely not brushed nickel or matt finish, it is a chrome like stainless finish.
Ralph
1972 Mercedes-Benz 280SEL 4.5
1988 Mercedes-Benz 560SL
2007 BMW 328xi (E90)
Italy
2004 Toyota HiLux D4D Pickup
