Author Topic: soft top  (Read 2886 times)
antonio martinez
  • Spain, Balearic Islands, palma de mallorca
soft top
« on: February 10, 2021, 11:40:25 »
Good morning to all.
I have a dilemma....
I have changed the soft top... and tight at the front, it does not close behind ...
Could the shims of the structure influence, or is it just because the fabric is new?
I understand that the shims are for the distance between the soft top and the window ... but ...
regards ;)
DaveB
Re: soft top
« Reply #1 on: February 10, 2021, 12:20:54 »
It is apparently a common issue and should come good with some stretching.
If you search the site for 'soft top stretching' you will find some creative ways to do it, e.g.:
https://www.sl113.org/forums/index.php?topic=22699.msg162342#msg162342
DaveB
'65 US 230sl 4-speed, DB190
antonio martinez
Re: soft top
« Reply #2 on: February 10, 2021, 13:25:54 »
Many thanks Dave
su8pack1
  • USA, PA, Barto
Re: soft top
« Reply #3 on: February 10, 2021, 16:11:14 »
I did this with mine and they published it in The Star back in 1987.
1984 300CD
1987 190E 2.6
1988 190D 2.5
DaveB
Re: soft top
« Reply #4 on: February 11, 2021, 06:16:29 »
Coincidentally I just saw your soft top stretch article in The 'Star Technical Reprints No. 2'. How is your top looking 33 years on?
Antonio, you should also be aware of two other soft top issues: corner curl and mechanical damage to the top fabric when opening & closing. This video shows how to prevent them:
https://www.youtube.com/watch?app=desktop&feature=youtu.be&v=dcvG2HfMat4&fbclid=IwAR1MW0egpotUS5d9JBoStZ7TLZT7eNK7PN2qeISJujD3L3lMSjo7WCDmi4E
DaveB
antonio martinez
Re: soft top
« Reply #5 on: February 11, 2021, 07:03:20 »
incredible!!
thanks to all.
I have tried and with a little effort, everything falls into place .... perfect.
I have not removed any shims.
then I send photos.
living on the wonderful Mediterranean island Majorca, we have a great climate, I can wear the soft top all year round ....
DaveB
Re: soft top
« Reply #6 on: February 11, 2021, 09:43:03 »
nice  :), but I hope you don't have too much salt spray in the air!
DaveB
su8pack1
  • USA, PA, Barto
Re: soft top
« Reply #7 on: February 11, 2021, 18:11:47 »
I finally replaced it as it was dried out to the point you could almost poke a hole through it with your finger. It took a weekend to do, but so far so good.
1984 300CD
1987 190E 2.6
1988 190D 2.5
