Author Topic: Coil spring compression tool  (Read 2429 times)
CJHenderson
  • USA, AR, Benton
« on: February 11, 2021, 16:53:44 »
Curious as to where to get a coil spring compression tool. The one that I bought from Amazon is the type that the compressor shaft goes through the center of the spring and through the plates. The one that I have the plates do not fit properly on the springs.
1950 MG-TD
Re: Coil spring compression tool
« Reply #1 on: February 11, 2021, 20:34:45 »
Which spring are you trying to compress?
CJHenderson
  • USA, AR, Benton
« Reply #2 on: February 11, 2021, 22:10:09 »
Front wheels
1950 MG-TD
CJHenderson
  • USA, AR, Benton
« Reply #3 on: February 12, 2021, 00:44:55 »
Found one at Pelican Parts specifically for 63-71 SL class. P/N PEL-013845SCH01A
1950 MG-TD
merrill
« Reply #4 on: February 13, 2021, 13:56:52 »
hi
if you search the forums or tech manual you will find a technique to remove the front springs without a compressor.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
« Reply #5 on: February 13, 2021, 15:38:56 »
Yes, there is a technique to do it - also in Haynes and BBB. But it is so scary....
dirkbalter
  • USA, CA, Corona
« Reply #6 on: February 13, 2021, 16:48:26 »
CJ,
may be that helps. Worked good for me.
« Last Edit: February 13, 2021, 17:12:46 by dirkbalter »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
CJHenderson
  • USA, AR, Benton
« Reply #7 on: February 13, 2021, 21:54:39 »
Really is a good idea but since I ordered the tool I'll try it but if that fails I will resort to what you did. Thanks to all for the advice.
1950 MG-TD
PeterPortugal
  • Portugal, Faro, Lagoa
« Reply #8 on: February 14, 2021, 10:16:22 »
CJ / Dirk,
I did both. I think it depends on the timing. If it is in the middle of a restoration and is high up with no engine installed that is one thing. Mine was just raised on axle stands. I think the 10mm threaded rods are essential for safety.
What I found is that the compression tool bought me enough room to safely get the springs and rods installed. Once this was done I tightened up the nuts on the rods to take up the slack. I then removed the compression tool and finished the job using the nuts on the threaded rods.
It took me a few attempts to optimise the position of the plates in the spring to make sure they compressed it enough and I could still get them out when the spring was fitted.
1963 220se Cabrio
1968 280se Coupe
