70 dollars for genuine mercedes discs ? Or pads?
pads + pins + springs
Sorry for not being precise.
For discs I went for Ate, like this:
https://allegro.pl/oferta/tarcze-mercedes-pagode-w113-2-3-63-67-10223175302This is more like $150 for 2, much more expensive in Mercedes, as part 154211112 64 costs $600 more or less. Maybe this is this EUR 1000 you mentioned. Yes if you buy discs + pads +screws + rear discs + rear pads - you would be somewhere close to EUR 1000.
Rear Ate discs are $75 more or less.
It is also a good idea to buy the screws when you replace the discs: for front - 10x A 000 990 72 12 @ $4.0. And have a good 10mm allen with long bit for impact gun to unscrew. At least my experience.
There is no "genuine" Mercedes discs or pads. They will also be form some producer, but they will for sure be of high quality, often even compared to same product OEM. Sorry, this is my theory, I know others think differently.
It has never crossed my mind to go Brembo, ceramic, etc., as I simply do not drive in the way I would need them. I also heard about a lot of surprises as some of these parts are made for aggressive driving and work not so well when driving slow.
