Author Topic: Suspension Differences -- 230/250/280  (Read 1967 times)
lowpad
  • USA, CT, New Preston
« on: February 14, 2021, 18:12:31 »
I am currently working on a book about Affordable Classics with a chapter on the W113 (and I realize that affordability is in the eye of the beholder!).  I've seen on several online auction sites (you can probably guess which ones) where commenters note that the 280SL has a softer / more compliant / less fun-to-drive etc. ride & handling setup.  Yet my unscientific survey of suspension components shows no part number-level distinction between the various models.  If there's no difference in the key components (ie, bushings, springs, shocks etc.), then there should be no difference in handling.
As I'm really only familiar with the 230SL, I'd appreciate feedback from the group so that I can state the facts correctly.
Lowell
1966 230SL (6/66 build)
French export
4-speed manual
158 Exterior / 040 Hardtop
2001 SLK230
1996 Porsche 993
1991 Acura NSX
AndrewB
  • , Channel Islands, Forest
Re: Suspension Differences -- 230/250/280
« Reply #1 on: February 14, 2021, 18:26:25 »
Hello Lowell, I am no expert, but think the difference between 230 and 280 is that the 230 had many suspension components that needed regular grease, whereas the 280 had these replaced with rubber bushes with no requirement for greasing.
There are many experts who will be able to give you detailed feedback, but I understand this to be the high level view
1969 280SL (unrestored)
1970 280SL (fully restored)
1971 Range Rover Suffix A Kingsley Restomod
1987 500SL
2002 Porsche 996 Targa
2011 Landrover Defender TdCi
2019 Mercedes S560 Cabriolet
« Reply #2 on: February 14, 2021, 19:10:29 »
This is the first time I've read this.
I would be very careful with these kinds of suggestive comments.
It's a very personal matter!
I have a 280SL and I can tell you it's fun to drive, and luckily it's not a BMW.
It is a car for cruising and enjoyment and if you need or want you can drive 1000 km a day without any problems, just fun….
^ Peter
lowpad
« Reply #3 on: February 14, 2021, 19:21:28 »
This is not my personal opinion, but rather comments I have read in online forums.  My question is a factual one -- was the W113 suspension tuning changed over its lifecycle?  If so, what components changed?  I've not been able to find any detailed evidence around this.
French export
4-speed manual
2001 SLK230
1996 Porsche 993
1991 Acura NSX
dirkbalter
  • USA, CA, Corona
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #5 on: February 14, 2021, 20:36:45 »
I believe the torsion bars are different by 2 mm. 230sl 22mm, later bar is 20mm. don’t know when the change was made.
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
« Reply #6 on: February 15, 2021, 15:58:00 »
Engelen/Mallory listed the torsion bar changed at 250 SL VIN ending 34 for US and A/C cars, then another listing at 250 SL VIN ending 339 simply as torsion bar change. There were no dimensions listed.
« Reply #7 on: February 15, 2021, 20:10:54 »
Maybe this helps, a lubrication overview.
« Reply #8 on: February 15, 2021, 21:38:59 »
As for the torsion bar this is what the system is saying for 113043:
World:
A 113 323 01 65 TORSION BAR Replaced with A 113 323 02 65 +1 A 110 323 04 85 (this is rubber mount)
Plant information: Until Chassis 0 05164
A 113 323 02 65 TORSION BAR FRONT 22 MM
USA and Canada
[003] 043 UP TO CHASSIS 005164
A 113 323 02 65 TORSION BAR 22 MM DIA.
[004] 043 FROM CHASSIS 005165
For 113042 (no differentiation of market):
A 113 323 00 65 TORSION BAR Replaced with A 113 323 01 65
Both front and rear springs had 3 part numbers for 113042, but just one for 113043 and 113044 - no info on chassis no. when chang ehappened.
