Author Topic: Clutch and brake pedal heights  (Read 1666 times)
col320ce
« on: February 18, 2021, 21:54:48 »
Should the brake and clutch pedals be the same hight? My brake is lower (closer to the firewall) than the clutch.
The assembly is on the bench so any adjustment would be easier now.
There are a half a dozen washers which are all on the side to make the pedal lower (on the brake light switch) ...
Thanks!
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
georgem
Re: Clutch and brake pedal heights
« Reply #1 on: February 21, 2021, 05:50:49 »
Maybe the brake is lower than the clutch to put it on a plane similar to the accelerator so its easy to move from one to the other without having to lift the right leg too far PLUS if you are a boy racer, it might make heel and toe changes easier :D
George McDonald
Brisbane
230 Sl
1973 VW Kombi Single Cab Ute
getsmart
  • Australia, Victoria, Dromana
« Reply #2 on: March 10, 2021, 12:06:04 »
Col mine is on the bench too, I'll check it in the morning if you're still interested,
Rgds, Joe
Finding the red car
1964 230sl Restoration Project
col320ce
« Reply #3 on: March 10, 2021, 12:18:06 »
Thanks mate.
Col
1964 230SL
1965 250SE coupe
getsmart
« Reply #4 on: March 11, 2021, 11:00:57 »
Col,
My brake pedal is about a cm higher than the clutch pedal. Doesn't look like there's been any mods anywhere.
Hope the pics help...
Rgds, Joe
Finding the red car
