with our official
Pagoda SL Group logo
from our official partner.
General Discussion
low temp switch
Topic: low temp switch (Read 2647 times)
low temp switch
April 17, 2005, 14:58:56 »
Finally decided to take the old switch off the car. It's located in the side of the engine block just beneath the FIP. It's made by VDO and labled 17C +2C-3C. It's part of the ignition system. Does anyone know the part number for this item?
Many Thanks!
Full Member
Platinum
USA, OH, Canal Winchester
Pagoda SL Group: 20+ years and going strong!
Re: low temp switch
April 17, 2005, 16:20:41 »
Jeff,
What system is this switch a part of, or what does it do?
1966 230SL, Euro, Auto, Leather, both tops
Re: low temp switch
Reply #2 on:
April 17, 2005, 16:44:27 »
Hi Rodd,
The switch is part of the ignition system. If the engine temperature is below 17C the switch is closed. In the closed position this switch causes the two way valve to remove vacumm pressure to the distributor causing the timing to advance with a pickup in idle speed. As the engine warms the switch opens and the two way valve returns vacumm to the distributor advance. I would say it works with the FIP thermostat to increase idle when cold and possibly reduce exhaust emissions.
General Discussion
low temp switch
